[postgis-devel] PostGIS 2.2 for PostgreSQL 9.5 Windows 64 bit
Pieter du Plooy pjduplooy at zpanelcp.com
Mon Oct 12 14:27:11 PDT 2015
Thx
Working now.
Pieter
On Mon, Oct 12, 2015 at 10:48 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Pieter,
> Thanks for reporting.  Hadn't had a chance to check the 9.5 yet after I
> built because I had to confirm a change they made in the VC++ builds that
> was different from prior editions so I had to make a special build for this
> separate from the others.
> In doing so I neglected to enable SFCGAL and address standardizer
> building.  Rebuilding now. Can you redownload in about 30 minutes.  Should
> then have SFCGAL and address_standardizer support.
> Thanks,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Pieter du Plooy
> *Sent:* Monday, October 12, 2015 12:01 PM
> *To:* postgis-devel at lists.osgeo.org
> *Subject:* [postgis-devel] PostGIS 2.2 for PostgreSQL 9.5 Windows 64 bit
> Hi guys
> I have just installed PG 9.5, and downloaded the PostGIS 2.2 for 9.5
> (Windows 64).
> I cannot create the sfcgal and address standardizer extensions.
> I get the following errors:
> ERROR:  could not stat file "C:/Program
> Files/PostgreSQL/9.5/share/extension/postgis_sfcgal--2.2.0.sql": No such
> file or directory
> and
> Files/PostgreSQL/9.5/share/extension/address_standardizer--2.2.0.sql": No
> such file or directory
> It is only the appropriate comments.sql for these two that exist.
> Could you please check?
> Regards
> Pieter du Plooy
> postgis-devel mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20151012/0eebb251/attachment.html>
