[postgis-devel] "SVN on behalf of" considered harmful
Greg Troxel
gdt at ir.bbn.com
Tue Oct 20 06:15:51 PDT 2015
Sandro Santilli <strk at keybit.net> writes:
> On Mon, Oct 19, 2015 at 07:55:52PM -0400, Greg Troxel wrote:
>> So I think this:
>> From: SVN on behalf of Sandro Santilli <strk at keybit.net>
>> should be
>> From: Sandro Santilli <strk at keybit.net>
>> which is how regular mail from strk@ looks.
>> This is not abuse of From:, because the message really is being
>> generated on behalf of the committing user, and contains comments whose
>> semantics are determined by the commit and commit message. It would be
>> appropriate to set a Sender: field to indicate this, although the
>> message goes to a mailinglist that will replace the sender field anyway.
> Right after replying to a commit notification from Regina I found
> myself agreeing with you as I wasn't really replying to "SVN" there...
> So I went ahead and removed the "SVN on behalf of" portion.
> And, you're right about the "Sender" header being replaced, as I'm now
> really setting it, but not receiving from the mailing list. Do you
> have other suggestions as to how specify the mail was automatically
> generated ? Any standard header for that ? Or should we just invent
> an X-Generated-By ?
I think you should just not worry about it and be happy. It is obvious
to all readers how the mail was generated, and there is no actual
problem to solve.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20151020/c91bc173/attachment.sig>
