[postgis-devel] postgis extension sans raster (only for folks who can't compile with raster support) - PSC Vote and developer/packager comments please
Paragon Corporation lr at pcorp.us
Sat Oct 24 11:14:03 PDT 2015
One FreeBSD packager brought up that they can't compile PostGIS with raster
support because of the QT dependency it drags in among others.  I still
don't quite understand why that's a big deal.
Anyway people complain because then they can't install postgis with
CREATE EXTENSION postgis;
Like everyone else.  I've seen similar complaints with Homebrew folks who
compile their own.
Rather than splitting raster out of postgis as many have proposed and
causing an upgrade mess for everybody , I propose this:
https://trac.osgeo.org/postgis/ticket/3338
In a nutshell: encode the lack of raster in the postgis version number
rather than the extension name itself.  This approach has the following
benefits (repeated from the ticket):
We still have raster as the default behavior and people still need to say
explicitly without-raster during configure.
1)    Most extensions that rely on PostGIS just use the vector portion, so
keeping the name the same they can continue on without having to change
their requires statement (changing requires is huge mess particularly for
extensions like pgRouting since then they'd have a different requires for
new PostGIS than older and they support 3 versions of each PostGIS minor)
Not to mention a huge mess for all the documentation already out there.
 2)   We have the same set of instructions for everybody:
3)    With the version differentiator it's trivial to upgrade a half-baked
version 2.3.0-no-raster to a full yummy 2.3.0 version. We just add upgrade
scripts to go from 2.3.0-no-raster to 2.3.0 regular postgis  (which is
pretty trivial exercise)
4)    Similarly we can have a 2.3.0--2.3.0-no-raster that gets installed if
you compile without raster support. Which will drop all the raster functions
during the upgrade.
5)    It's fairly trivial to do compared to returning not supported I was
thinking of before.
What do folks think about this? Am I nuts or is this a great idea?
If all are for it, I'm willing to do the work to make it happen for 2.3.0
Thanks,
Regina
