[postgis-devel] astyle again
Sandro Santilli strk at keybit.net
Wed Apr 27 08:47:44 PDT 2016
I've pushed an "astyle" branch to this git repository
https://git.osgeo.org/gogs/postgis/postgis.git
In the branch, I've dropped the "make astyle" check
for astyle version so you can run that command with
any version.
Then I've tweaked the style to keep lines within 78 columns
and run it on the code base.
This was done with Artistic Style Version 2.03
Could you please check out that branch, run "make astyle"
again and report if anything changes (or not), with
your versions ?
Please report here:
https://trac.osgeo.org/postgis/ticket/3538
Thanks!
--strk;
