[postgis-devel] Postgis 2.3.1 regression test failure on NetBSD-7 amd64
Greg Troxel gdt at lexort.com
Mon Dec 5 07:06:42 PST 2016
I am updating pkgsrc to 2.3.1 (from 2.2.2), and I got a regression test
failure.  This is with gcc 4.8 and postgresql 9.3.  Everything else
seems ok.    I wonder if this is a situation where a range of behavior
is acceptable, and the test has a limit, or if this indicates that
something really is wrong.   The test cluster was on a spinning disk
that also holds src/obj for an OS recompile, so this isn't a
particularly high-performance setup.
--- interrupt_relate_expected   2015-08-04 05:08:19.000000000 -0400
+++ /tmp/pgis_reg/test_108_out  2016-12-05 10:00:47.000000000 -0500
@@ -1,5 +1,5 @@
 ERROR:  canceling statement due to statement timeout
-contains interrupted on time
+contains interrupted late: 00:00:00.274858
 covers interrupted on time
