[postgis-devel] BOX3D strange behaviour
Rémi Cura remi.cura at gmail.com
Thu Feb 18 01:22:53 PST 2016
Great !
I'll try that and see how much faster it is !
Cheers,
Rémi-C
2016-02-18 10:17 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> Le jeudi 18 février 2016 10:03:54, Rémi Cura a écrit :
> > So what is the point to have a Box3D,
> >  as any use of it requires it to be casted to geometry,
> > which turns it into a box2D?
> > (Maybe I missed a way to use this 3D box with a 3D index so it uses Z? )
> > Is there any way to perform &&& in all 3 dimensions?
> > My problem is "give points whose X, Y, Z are inside the range R1,R2,R3",
> > and I'd prefer have one 3D geom gist index rather than 3 btree index on
> > coordinates.
> > I was thinking the 3DBox was smart, untill I spent quite some time
> tracking
> > subsequent errors to postgis.
> The following hack seems to work :
> SELECT  st_geomfromtext('multipoint z (0 0 0,10 10 10)')  &&&
> ST_Makepoint(5,5,-1);
>  ?column?
>  f
> (1 ligne)
> ST_Makepoint(5,5,3);
>  ?column?
>  t
> (1 ligne)
> > Cheers,
> > Rémi-C
> > 2016-02-18 9:53 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> > > Le jeudi 18 février 2016 09:37:41, Sandro Santilli a écrit :
> > > > On Wed, Feb 17, 2016 at 11:33:12AM -0800, Paul Ramsey wrote:
> > > > > > On Feb 17, 2016, at 10:46 AM, Rémi Cura <remi.cura at gmail.com>
> > > > > > wrote:
> > > > > > SELECT 'BOX3D( 0 0 0, 10 10 10)'::box3D::geometry &&&
> > > > > select st_astext('BOX3D( 0 0 0, 10 10 10)'::box3D::geometry);
> > > > Horrible. box3d::geometry drops the Z ?
> > > > Was it always like that ?
> > > Seems so:
> > > => select postgis_version(), st_astext('BOX3D( 0 0 0, 10 10
> > >             postgis_version            |             st_astext
> > >  1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 | POLYGON((0 0,0 10,10 10,10 0,0
> > >  0))
> > > (1 ligne)
> > >  2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 | POLYGON((0 0,0 10,10 10,10 0,0
> > >  0))
> > > > --strk;
> > > > _______________________________________________
> > > > postgis-devel mailing list
> > > > postgis-devel at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/postgis-devel
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160218/4496d3ff/attachment.html>
