[postgis-devel] ST_MakeLine repeated point behavior
Paul Norman penorman at mac.com
Wed Feb 24 08:15:40 PST 2016
I was working on extending ST_MakePoint to handle MULTIPOINTs when I ran
across some inconsistent behavior.
When ST_MakeLine is called with an array, the LINESTRINGs in it are
added to the output with removal of duplicate points, but POINTs are
called without removal. The regression tests cover the former but not
the latter. The linestring behavior is documented, but there is no
mention of removal or not for repeated points.
As an example, calling it with a linestring from A to B and one from to
B to C results in a linestring from A to B to C. Calling it with points
at A, B, B, and C results in a linestring from A to B to B to C. Both
are valid linestrings.
I do not see that there are validity implications for the behavior -
invalid single-vertex linestrings can be generated with either behavior.
What is the best behavior to use here? It would make the code cleaner if
there was consistent behavior for points and linestrings.
