[postgis-devel] BOX3D strange behaviour
Paul Ramsey pramsey at cleverelephant.ca
Fri Feb 26 04:02:12 PST 2016
Nope, make it So
On Fri, Feb 26, 2016 at 12:41 PM, Daniel Baston <dbaston at gmail.com> wrote:
> There's now a pull request to address this:
> https://github.com/postgis/postgis/pull/92
> The only places in the regression suite where a BOX3D->geometry cast is
> executed are places where a (user-input) BOX3D literal is explicitly cast to
> a geometry.  So, there shouldn't be a performance hit or ill effect of
> having the BOX3D->geometry cast produce a PolyhedralSurface, as Even
> suggests.
> Any objections to this?
> Dan
> On Thu, Feb 18, 2016 at 8:02 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Le jeudi 18 février 2016 10:49:52, Sandro Santilli a écrit :
>> > On Thu, Feb 18, 2016 at 10:03:54AM +0100, Rémi Cura wrote:
>> > > Is there any way to perform &&& in all 3 dimensions?
>> > Our boxes are all broken.
>> > There should be somewhere a wiki page or ticker or something about
>> > options to improve the situation. IIRC it boiled down to:
>> >  1) Have a BOX geometry type (like LINESTRING/POINT/POLYGON)
>> >  2) Expose a GBOX postgresql type (like BOX2D, BOX3D)
>> > Recently, I've started using 2-vertices linestrings to simulate
>> > the equivalent of a "BOX geometry type". It is the value returned
>> > by http://postgis.net/docs/ST_BoundingDiagonal.html
>> > You can easily create such object via ST_MakeLine:
>> > http://postgis.net/docs/ST_MakeLine.html
>> > It will support SRID and all supported dimensions.
>> > Changing the BOX3D->Geometry cast ? I'm all for it, and I'd have
>> > it return a "bounding diagonal" too...
>> Naively, I would rather have expected a BOX3D to be converted as a
>> PolyhedralSurface, but there might be implications in doing so.
>> > --strk;
>> > _______________________________________________
>> > postgis-devel mailing list
>> > postgis-devel at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/postgis-devel
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
