[postgis-devel] PostgreSQL 9.5.0 has just been stamped
Greg Troxel gdt at ir.bbn.com
Mon Jan 4 17:55:38 PST 2016
"Paragon Corporation" <lr at pcorp.us> writes:
> Slight correction.  PostgreSQL 9.5.0 has been stamped, not yet released :).
> Packagers embargo is on.
> So we still have probably 1-2 days so to catch the train.
I am really not following this.  Are you saying that postgis-current
does not work with 9.5.0?  Or that 2.2.0 doesn't?  And are you implying
that somehow postgis is expected to work immediately when there is a new
postgresql version?   I don't see the panic; 9.5.0 is by definition
bleeding edge, and certainly is going to take a at least a little bit to
show up in packaging systems.
If postgis is supposed to work with new postgresql versions, then it
seems clear that there has to be a regular process of testing with the
postgresql branches leading up to release well before the release
happens.
Doing anything in a several-days trimeframe seems like a recipe for
mistakes.
Sort of separately, I'm not sure what the 2.2.1 plan is, but given that
people have other things to do, it seems there should be a more-or-less
freeze with a week for people to pre-package and check things.  It will
probably take me an hour to test.  It seems the time to test is now, as
it feels like no more changes are planned.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160104/8e24aa13/attachment.sig>
