[postgis-devel] KNN and 9.5
Brian M Hamlin maplabs at light42.com
Tue Jan 5 20:54:25 PST 2016
(you can get the natural_earth2 data set from the OSGeo Live -- its one
of the main sample databases)
  --Brian
On Tue, 5 Jan 2016 23:04:32 -0500, Paragon Corporation  wrote:
       Gives me a 404.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
Behalf Of Stephen Mather
Sent: Tuesday, January 05, 2016 10:31 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] KNN and 9.5
Hi Regina,
The dataset is from Natural
Earth: http://www.naturalearthdata.com/http//www.naturalearthdata.com/download/10m/physical/ne_10m_geography_regions_polys.zip
I imported that dataset and transformed to 3857 just to get it in
planar coordinates. I affectionately called it regions_polys_subset.
https://gist.github.com/smathermather/320273309124bf8b80a7
But honestly, as long as you throw the knn in a function, any point
dataset will do it, I think.
Hope this helps (and helps in time!)!
Cheers,
Best,
Steve
On Sun, Jan 3, 2016 at 9:24 PM, Paragon Corporation  wrote:
       Steve,
Well that sucks.  Can I borrow your dataset to test with?
Thanks,
Regina
Sent: Sunday, January 03, 2016 10:41 AM
Hi Regina,
On a lark, I also tested with 2.3.0dev r14538 (9.5rc1)
"POSTGIS="2.3.0dev r14538" GEOS="3.5.0-CAPI-1.9.0 r4084" SFCGAL="1.2.2"
PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26"
LIBXML="2.9.1" LIBJSON="0.11.99" RASTER"
Same result.
Cheers,
Best,
Steve
On Sun, Jan 3, 2016 at 9:34 AM, Stephen Mather  wrote:
       2.2.0 and RC1. Should I be trying 2.2 branch?
SELECT version();
"PostgreSQL 9.5rc1 on x86_64-pc-linux-gnu, compiled by gcc (Debian
4.7.2-5) 4.7.2, 64-bit"
SELECT postgis_full_version();
"POSTGIS="2.2.0 r14208" GEOS="3.5.0-CAPI-1.9.0 r4084" SFCGAL="1.2.2"
On Sun, Jan 3, 2016 at 2:18 AM, Paragon Corporation  wrote:
       Steve,
Haven't had a chance to look thru what you have here and test it out myself.
The issue I flagged in the ticket was fixed in PostgreSQL 9.5 code base
upstream:
http://www.postgresql.org/message-id/55630D9D.3090508@iki.fi
It's my understanding that you should never get that notice again.  So
I'm a bit concerned you are.  It's possible you found another area
where this issue arises and is not handled.
Are you running PostgreSQL 9.5RC1 and latest PostGIS 2.2 branch (or 2.2.0?).
Thanks,
Regina
Sent: Sunday, January 03, 2016 1:56 AM
Subject: [postgis-devel] KNN and 9.5
Hi All,
Short version:
Does Regina's comment on http://trac.osgeo.org/postgis/ticket/2703
regarding ERROR: index returned tuples in wrong order apply to any
uses of indices in conjunction with KNN?
Long version:
Digging many of the 2.2 / 9.5 updates. Having fun on break playing with
skeleton simplification and using KNN in the process. Yes. For those of
you who know me, this is an obsession that won't die quietly.
https://smathermather.files.wordpress.com/2016/01/screen-shot-2016-01-03-at-1-19-26-am.png
I've got a function that does my KNN in the usual style, finds the
nearest 2 points, and makes a line from them:
CREATE OR REPLACE FUNCTION zz_knn_wonderful_points (geometry) RETURNS
geometry AS $$
-- Here are my wonderful points to KNN search:
WITH index_query AS (
            SELECT edge.geom AS geom
            FROM (SELECT * FROM regions_dpoints WHERE gid = 882) AS edge
-- This is my query point
            ORDER BY $1
            edge.geom LIMIT 2
SELECT ST_MakeLine(geom) FROM index_query
$$ LANGUAGE SQL;
The intent is to implement angle values as an importance criterion for
simplifying the skeleton as described at minute 2:20 in Balint Miklos
video on the scale axis
transform: http://balintmiklos.com/scale-axis/The_Scale_Axis_Picture_Show.mp4
Actually, in the final function, I will likely directly calculate the
angle and return that instead of the geometry, but I digress.
Regardless, when I use this function as is, it works great in drawing
lines connecting the two nearest points to the vertex in the medial
axis:
DROP TABLE IF EXISTS test CASCADE;
CREATE TABLE test AS
WITH returnline AS (
            SELECT oid, gid,
                        ST_Union(
                        ST_MakeLine(
ST_StartPoint(zz_knn_wonderful_points(subset.geom)), subset.geom),
                        ST_MakeLine(
ST_EndPoint(zz_knn_wonderful_points(subset.geom)), subset.geom)
                        AS geom FROM
                        (SELECT * FROM regions_points WHERE oid = 882) subset
SELECT * FROM returnline
However, as implemented, this will not work in the case of overlapping
geometries, such as Natural Earth's label polygon dataset
"ne_10m_geography_regions_polys":
https://smathermather.files.wordpress.com/2016/01/screen-shot-2016-01-03-at-1-33-01-am.png
And so I add a constraint using an integer ID:
CREATE OR REPLACE FUNCTION zz_knn(integer,geometry) RETURNS geometry AS $$
            FROM (SELECT * FROM regions_dpoints WHERE gid = $1) AS edge
            ORDER BY $2
            edge.geom LIMIT 2
$$ LANGUAGE SQL;
And now it takes much longer and fails with
CONTEXT:  SQL function "zz_knn" statement 1
********** Error **********
SQL state: XX000
Context: SQL function "zz_knn" statement 1
Thanks!
Cheers,
Best,
Steve Mather
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/postgis-devel
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160105/e857e025/attachment.html>
