[postgis-devel] postgis trunk fails to build with 2.2.1 installed
Sandro Santilli strk at keybit.net
Sun Jan 10 23:23:19 PST 2016
On Sat, Jan 09, 2016 at 08:35:23PM -0500, Greg Troxel wrote:
> I'm not sure what the group wants to do about this.  liblwgeom.h is an
> internal library, and installed versions should not be looked at.  So I
> would recommend the ../liblwgeom/ change above for all uses, including
> _internal.h, but I am not 100% confident this is right.
I *think* making sure -I../liblwgeom appearing before any of the system
directories should also fix the problem, and would be less invasive,
could you confirm that with your compiler ?
--strk;
