[postgis-devel] spatial_ref_sys maintainance
Sandro Santilli strk at keybit.net
Thu Jan 28 01:20:02 PST 2016
I've seen spatial_ref_sys was first updated with some automatic
export from GDAL and then manually tweaked to add "historical manual
diffs" [1].
Is the process documented somewhere ? How can we ensure these manual
diffs are always retained in the future ?
Also, updating that table currently requires manually tweaking
the extensions/postgis/sql_bits/mark_editable_objects.sql.in file,
which is error prone [2]. Can it be automated to reduce the risk ?
[1] https://trac.osgeo.org/postgis/ticket/3427
[2] https://trac.osgeo.org/postgis/ticket/3443
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
