[postgis-devel] Building Postgris on Solaris 11
Paul Ramsey pramsey at cleverelephant.ca
Tue Jul 5 05:04:19 PDT 2016
I should have sent this at the time, but it didn't answer your
proximate problem since you were building w/ the Sun compiler...
https://github.com/pramsey/suite-solaris-build/blob/master/pgsql-postgis-gdal-build.sh
P.
On Tue, Jul 5, 2016 at 4:29 AM, Andrew Watkins <andrew at dcs.bbk.ac.uk> wrote:
> On 06/30/16 16:28, Andrew Watkins wrote:
> Hello folks,
> Beening battling my way through Postgis on Solaris and I am getting close
> but still getting errors. Here is the relevant information and any pointers:
> postgis-2.2.2# ./configure CC=/opt/studio12u1/bin/cc CFLAGS="-m64
> -DNAN=\"(0.0/0.0)\"" CPPFLAGS=-m64 CXXFLAGS=-m64 LDFLAGS="-m64
> -L/usr/local/postgres/pgdg/lib/64 -L/usr/local/postgres/geos/lib
> -L/usr/local/postgres/proj4/lib" \
>     --with-pgconfig=/usr/local/postgres/pgdg/bin/64/pg_config \
>     --with-geosconfig=/usr/local/postgres/geos/bin/geos-config \
>     --with-gdalconfig=/usr/local/postgres/gdal/bin/gdal-config \
>     --with-projdir=/usr/local/postgres/proj4
>   PostGIS is now configured for i386-pc-solaris2.11
>  -------------- Compiler Info -------------
>   C compiler:           /opt/studio12u1/bin/cc -m64 -DNAN="(0.0/0.0)"
>   SQL preprocessor:     /usr/gcc/4.5/bin/cpp -traditional-cpp -w -P
>  -------------- Dependencies --------------
>   GEOS config:          /usr/local/postgres/geos/bin/geos-config
>   GEOS version:         3.5.0
>   GDAL config:          /usr/local/postgres/gdal/bin/gdal-config
>   GDAL version:         2.1.0
>   PostgreSQL config:    /usr/local/postgres/pgdg/bin/64/pg_config
>   PostgreSQL version:   PostgreSQL 9.5.3
>   PROJ4 version:        49
>   Libxml2 config:       /usr/bin/xml2-config
>   Libxml2 version:      2.9.2
>   JSON-C support:       yes
>   PCRE support:         no
>   PostGIS debug level:  0
>   Perl:                 /usr/bin/perl
>  --------------- Extensions ---------------
>   PostGIS Raster:       enabled
>   PostGIS Topology:     enabled
>   SFCGAL support:       disabled
>   Address Standardizer support:       disabled
>  -------- Documentation Generation --------
>   xsltproc:             /usr/bin/xsltproc
>   xsl style sheets:
>   dblatex:
>   convert:
>   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> # make
> /usr/bin/perl ../utils/postgis_proc_set_search_path.pl postgis.sql UNUSED >
> postgis_proc_set_search_path.sql
> /usr/gcc/4.5/bin/cpp -traditional-cpp -w -P -I../libpgcommon legacy.sql.in |
> grep -v '^#' | \
> /usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.2'g" > legacy.sql
> /usr/bin/perl ../utils/create_undef.pl legacy.sql 95 > uninstall_legacy.sql
> legacy_minimal.sql.in | grep -v '^#' | \
> legacy_minimal.sql
> legacy_gist.sql.in | grep -v '^#' | \
> legacy_gist.sql
> make[1]: Leaving directory `/tmp/postgis-2.2.2/postgis'
> ---- Making all in regress
> make[1]: Entering directory `/tmp/postgis-2.2.2/regress'
> make[1]: Nothing to be done for `all'.
> make[1]: Leaving directory `/tmp/postgis-2.2.2/regress'
> ---- Making all in raster
> make[1]: Entering directory `/tmp/postgis-2.2.2/raster'
> make -C rt_core
> make[2]: Entering directory `/tmp/postgis-2.2.2/raster/rt_core'
> /opt/studio12u1/bin/cc -m64 -DNAN="(0.0/0.0)"  -KPIC -DPIC
> -I../../liblwgeom -I/usr/local/postgres/gdal/include
> -I/usr/local/postgres/proj4/include -I/usr/local/postgres/geos/include   -c
> -o rt_util.o rt_util.c
> "/usr/local/postgres/gdal/include/ogr_core.h", line 415: warning: enumerator
> value overflows INT_MAX (2147483647)
> "/usr/local/postgres/gdal/include/ogr_core.h", line 416: warning: enumerator
> "/usr/local/postgres/gdal/include/ogr_core.h", line 417: warning: enumerator
> "/usr/local/postgres/gdal/include/ogr_core.h", line 418: warning: enumerator
> "/usr/local/postgres/gdal/include/ogr_core.h", line 419: warning: enumerator
> "/usr/local/postgres/gdal/include/ogr_core.h", line 420: warning: enumerator
> "/usr/local/postgres/gdal/include/ogr_core.h", line 421: warning: enumerator
> "librtcore.h", line 151: warning: macro redefined: __attribute__
> "librtcore.h", line 245: syntax error before or at: (
> "librtcore.h", line 244: function cannot return function or array
> "librtcore.h", line 245: warning: function prototype parameters must have
> types
> "librtcore.h", line 245: warning: syntax error:  empty declaration
> "/usr/include/assert.h", line 23: syntax error before or at: (
> "/usr/include/assert.h", line 23: function cannot return function or array
> "rt_util.c", line 142: warning: statement not reached
> "rt_util.c", line 173: warning: statement not reached
> cc: acomp failed for rt_util.c
> make[2]: *** [rt_util.o] Error 2
> make[2]: Leaving directory `/tmp/postgis-2.2.2/raster/rt_core'
> make[1]: *** [corelib] Error 2
> make[1]: Leaving directory `/tmp/postgis-2.2.2/raster'
> make: *** [all] Error 1
> I have tried it with gcc but I get the same error.
> Well, it looks like people don't use Solaris for PostGIS or they don't share
> there findings.
> I do like sharing here are is my blog entries for compiling PostGIS on
> Solaris 11
> http://notallmicrosoft.blogspot.co.uk/2016/07/install-postgis-on-solaris-11-113.html
> Only bad news is that I have not managed to get all modules working, but it
> is a start.
> Anyway, hope it helps others.
> Andrew Watkins * Birkbeck, University of London * Computer Science *
> * http://notallmicrosoft.blogspot.com *
> * UKOUG Systems SIG Chair *
> * UKOUG Tech committee *
> * tel: 020 7631 6720 *
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
