[postgis-devel] trunk build failure due to bad search path for liblwgeom includes
Greg Troxel gdt at ir.bbn.com
Sat Jul 30 07:18:29 PDT 2016
Since I'm hearing about the possibility of 2.3.0, I tried to build
trunk.  It failed with the following, in which one can clearly see that
the order of includes is wrong, picking up the installed directories
before the local liblwgeom (and the installed older version was read).
Before I file a ticket, does anyone think one is open (I couldn't find
it, but there are 521 open tickets so I could well have missed it).
gmake[1]: Entering directory '/usr/home/gdt/SOFTWARE/GEO/postgis/postgis'
gcc -O2 -I/usr/include -I/usr/pkg/include -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -fpic -DPIC -I../liblwgeom -I../libpgcommon  -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2     -fPIC -I. -I. -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -I/usr/include -I/usr/pkg/include   -c -o lwgeom_functions_analytic.o lwgeom_functions_analytic.c
lwgeom_functions_analytic.c: In function ‘ST_MinimumBoundingRadius’:
lwgeom_functions_analytic.c:1088:2: error: ‘LWBOUNDINGCIRCLE’ undeclared (first use in this function)
lwgeom_functions_analytic.c:1088:2: note: each undeclared identifier is reported only once for each function it appears in
lwgeom_functions_analytic.c:1088:20: error: ‘mbc’ undeclared (first use in this function)
lwgeom_functions_analytic.c:1089:2: warning: ISO C90 forbids mixed declarations and code
lwgeom_functions_analytic.c:1111:3: warning: implicit declaration of function ‘lwgeom_calculate_mbc’
lwgeom_functions_analytic.c:1123:3: warning: implicit declaration of function ‘lwboundingcircle_destroy’
lwgeom_functions_analytic.c: In function ‘ST_GeometricMedian’:
lwgeom_functions_analytic.c:1215:2: warning: implicit declaration of function ‘lwgeom_median’
lwgeom_functions_analytic.c:1215:11: warning: assignment makes pointer from integer without a cast
gmake[1]: *** [<builtin>: lwgeom_functions_analytic.o] Error 1
and configure output:
  PostGIS is now configured for x86_64-unknown-netbsd6.1.
 -------------- Compiler Info -------------
  C compiler:           gcc -g -O2
  SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
 -------------- Dependencies --------------
  GEOS config:          /usr/pkg/bin/geos-config
  GEOS version:         3.5.0
  GDAL config:          /usr/pkg/bin/gdal-config
  GDAL version:         1.11.3
  PostgreSQL config:    /usr/pkg/bin/pg_config
  PostgreSQL version:   PostgreSQL 9.3.13
  PROJ4 version:        49
  Libxml2 config:       /usr/pkg/bin/xml2-config
  Libxml2 version:      2.9.4
  JSON-C support:       no
  PCRE support:         no
  PostGIS debug level:  0
  Perl:                 /usr/pkg/bin/perl
 --------------- Extensions ---------------
  PostGIS Raster:       enabled
  PostGIS Topology:     enabled
  SFCGAL support:       disabled
  Address Standardizer support:       disabled
 -------- Documentation Generation --------
  xsltproc:             /usr/pkg/bin/xsltproc
  xsl style sheets:
  dblatex:
  convert:              /usr/pkg/bin/convert
  mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160730/ca79345c/attachment.sig>
