[postgis-devel] trunk passes checks on netbsd-6 amd64
Greg Troxel
gdt at ir.bbn.com
Sat Jul 30 09:26:42 PDT 2016
I did a build of trunk on netbsd-6 amd64 with the following, and after
working around the ticket:3602 build issue, got a a successful make
check (including the new json-c stuff, which had failed before I added
that to configure).
PostgreSQL 9.3.13 on x86_64--netbsd, compiled by gcc (NetBSD nb2 20110806) 4.5.3, 64-bit
Postgis 2.3.0dev - r15025 - 2016-07-30 16:19:19
scripts 2.3.0dev r15025
GEOS: 3.5.0-CAPI-1.9.0 r4084
PROJ: Rel. 4.9.2, 08 September 2015
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160730/6c8eac44/attachment.sig>
