[postgis-devel] postgis_tiger geocoding extension : France & temporal geocoding
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jun 16 06:15:41 PDT 2016
Hi Remi,
I have started a project to create an address standardizer that can be
internationalized with the longer term goal of redesigning the postgis
geocoder to work with data from any data sources.
https://github.com/woodbri/address-standardizer
The design for a generic geocoder works like this:
* load street data into a table with geometry
* standardize the street data into a standardized table
* given a query address
   * standardize it
   * generate a query to search for candidate records in the standized table
   * score/filter the candidate records
   * fetch the geometry and compute the location
The address-standardizer needs some performance tuning as it has
problems when the lexicon gets large and/or when the grammar gets too
complex.
I'm still fairly new at C++, and would be happy to get pull requests or
a code review.
I have a sample lexicon and grammar for France and it should be straight
forward to add a dimension like date to the scheme above and filter
candidate records based on dates in the scoring process.
I would be happy to work with you on this and discuss how to best solve
these problems.
Thanks,
   -Steve
On 6/16/2016 6:10 AM, Rémi Cura wrote:
> Hey dear list,
> I'm currently considering extending postgis geocoder.
> I have two needs:
>  - to work with French data
>  - to perform temporal geocoding (you give an addresses *and *a date,
> you get geographic position).
> For the moment I'm trying to understand how the geocoder works with USA
> data.
> I imported Massachusetts for a test, and everything seems okay except
> that my tiger.state table is empty, which prevents geocoding.
> Notwithstanding the import step, and the adress normaliser, it seems to
> boil down to a large query in the function tiger.geocode_address().
> I would be delighted to have some pointers on the design of the
> postgis_tiger_geocoder extension.
> In perticular, I don't understand the adress standardizer business at
> all (yeah, I found some doc, no, I don't understand it well)
> Many thanks for help,
> Cheers,
> Rémi-C
> WITH a AS
>          SELECT   *
>          FROM     (
>                              SELECT     f.*,
>                                         ad.side,
>                                         ad.zip,
>                                         ad.fromhn,
>                                         ad.tohn,
>                                         Rank() over(ORDER BY
> Diff_zip(ad.zip,'01104')*2.00 +
>                                         CASE
>                                                    WHEN Lower(f.name
> <http://f.name>) = Lower('FRANKLIN') THEN 0
>                                                    ELSE
> Levenshtein_ignore_case(f.name <http://f.name>, Lower('FRANKLIN') )
>                                         END +
> Levenshtein_ignore_case(f.fullname, Lower('FRANKLIN'
>                                                    || Coalesce('ST','')) ) +
>                                         CASE
>                                                    WHEN (
> Greatest_hn(ad.fromhn,ad.tohn) % 2)::INTEGER = ('1' % 2)::INTEGER THEN 0
>                                                    ELSE 1
>                                         END +
>                                         CASE
>                                                    WHEN '1'::INTEGER
> BETWEEN Least_hn(ad.fromhn,ad.tohn) AND        Greatest_hn(ad.fromhn,
> ad.tohn) THEN 0
>                                                    ELSE 4
>                                         END +
>                                         CASE
>                                                    WHEN Lower('ST') =
> Lower(f.suftypabrv)
>                                                    OR
> Lower('ST') = Lower(f.pretypabrv) THEN 0
>                                                    ELSE 1
>                                         END + Rate_attributes(NULL,
> f.predirabrv, 'FRANKLIN', f.name <http://f.name> , 'ST', suftypabrv ,
> NULL, sufdirabrv, prequalabr) ) AS rank
>                              FROM
> tiger.featnames
> AS f
>                              inner join
> tiger.addr
> AS ad
>                              ON         (
>                                                    f.tlid = ad.tlid)
>                              WHERE      '25' = f.statefp
>                              AND        '25' = ad.statefp
>                              AND        (
>                                                    Lower(f.fullname)
> LIKE (Coalesce(NULL
> Lower('FRANKLIN')
>                                                               || '%')::text
>                                         OR         Lower(f.name
>                                         OR         Soundex(f.name
> <http://f.name>) = Soundex('FRANKLIN') )
>                              AND        (
>                                                    ad.zip =
> ANY('{01102,01103,01104,01105,01106}'::VARCHAR[]) ) ) AS foo
>          ORDER BY rank limit 30 )
> , b AS (
>                   SELECT     a.tlid,
>                      a.fullname,
>                      a.name <http://a.name>,
>                      a.predirabrv,
>                      a.suftypabrv,
>                      a.sufdirabrv,
>                      a.prequalabr,
>                      a.pretypabrv,
>                      b.the_geom,
>                      tfidr,
>                      tfidl,
>                      a.side ,
>                      a.fromhn,
>                      a.tohn,
>                      a.zip,
>                      p.name <http://p.name> AS place
>                   FROM       a
>                   inner join tiger.edges AS b
>                   ON         (
>                             a.statefp = b.statefp
>                      AND        a.tlid = b.tlid )
>                   inner join tiger.faces AS f
>                   ON         (
>                             '25' = f.statefp
>                      AND        ( (
>                                       b.tfidl = f.tfid
>                                    AND        a.side = 'L')
>                             OR         (
>                                       b.tfidr = f.tfid
>                                    AND        a.side = 'R' ) ))
>                   inner join tiger.place p
>                   ON         (
>                             '25' = p.statefp
>                      AND        f.placefp = p.placefp )
>                   WHERE      a.statefp = '25'
>                   AND        b.statefp = '25' )
> , sub AS  (
>     SELECT   tlid,
>            predirabrv,
>            coalesce(b.prequalabr
>                 || b.name <http://b.name> AS fename,
>            suftypabrv,
>            sufdirabrv,
>            fromhn,
>            tohn,
>            side,
>            zip,
>            rate_attributes(NULL, predirabrv, 'FRANKLIN', b.name
> <http://b.name> , 'ST', suftypabrv , NULL, sufdirabrv, prequalabr) +
>            CASE
>                 WHEN '1'::INTEGER IS NULL
>                 OR       b.fromhn IS NULL THEN 20
>                 WHEN '1'::    INTEGER >= least_hn(b.fromhn, b.tohn)
>                 AND      '1'::INTEGER <= greatest_hn(b.fromhn,b.tohn)
>                 AND      (
>                           '1'::INTEGER % 2) =
> (to_number(b.fromhn,'99999999') % 2)::INTEGER THEN 0
>                 WHEN '1'::    INTEGER >= least_hn(b.fromhn,b.tohn)
>                 AND      '1'::INTEGER <= greatest_hn(b.fromhn,b.tohn) THEN 2
>                 ELSE ((1.0 -
> (least_hn('1'::text,least_hn(b.fromhn,b.tohn)::text)::NUMERIC /
> (greatest(1,greatest_hn('1'::text,greatest_hn(b.fromhn,b.tohn)::text)))
> )) * 5)::INTEGER + 5
>            END::INTEGER AS sub_rating,
>            '1'::INTEGER >= least_hn(b.fromhn,b.tohn)
>       AND      (
>                 '1' % 2)::NUMERIC::INTEGER =
> (to_number(b.fromhn,'99999999') % 2) AS exact_address,
>            b.name <http://b.name>,
>            b.prequalabr,
>            b.pretypabrv,
>            b.tfidr,
>            b.tfidl,
>            b.the_geom,
>            b.place
>       FROM     b
>       ORDER BY 10 ,
>            11 DESC limit 20 )
> --, foo AS (
>     SELECT DISTINCT
>          ON (
>  sub.predirabrv,sub.fename,coalesce(sub.suftypabrv, sub.pretypabrv)
> ,sub.sufdirabrv,sub.place,s.stusps,sub.zip) sub.predirabrv AS fedirp,
>                  sub.fename,
>                  coalesce(sub.suftypabrv, sub.pretypabrv) AS fetype,
>                  sub.sufdirabrv                           AS fedirs,
>                  sub.place ,
>  s.stusps
> AS state,
>  sub.zip
> AS zip,
>                  interpolate_from_address('1', sub.fromhn, sub.tohn,
> sub.the_geom,
> sub.side)
> AS address_geom,
>                  (sub.sub_rating + least(coalesce(diff_zip('01104' ,
> sub.zip),0), 20)*2.00 + coalesce(levenshtein_ignore_case('SPRINGFIELD',
> sub.place),5) )::INTEGER AS sub_rating,
>  sub.exact_address
> AS exact_address,
>                  sub.tohn,
>                  sub.fromhn
>          FROM           sub
>          join            tiger.state s
>          ON              (
>                          '25' = s.statefp)
>          ORDER BY        1,
>                  2,
>                  3,
>                  4,
>                  5,
>                  6,
>                  7,
>                  9 limit 20)
> SELECT   *
> FROM foo
> ORDER BY sub_rating,
>          exact_address DESC limit 100
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
