[postgis-devel] postgis_tiger geocoding extension : France & temporal geocoding
Rémi Cura remi.cura at gmail.com
Fri Jun 17 02:22:09 PDT 2016
Thanks for the anwser Stephen and Regina,
it really helps to provide some broader context about a project history and
purpose.
@Stephen I'll contact you in private about that.
Cheers,
Rémi-C
2016-06-17 7:30 GMT+02:00 Regina Obe <lr at pcorp.us>:
> > On Thu, Jun 16, 2016 at 6:10 AM, Rémi Cura <remi.cura at gmail.com> wrote:
>    >  Hey dear list,
>   >  I'm currently considering extending postgis geocoder.
>   >  I have two needs:
>  >    - to work with French data
>  >    - to perform temporal geocoding (you give an addresses and a date,
> you
> get geographic position).
> >    For the moment I'm trying to understand how the geocoder works with
> USA
> data.
> >    I imported Massachusetts for a test, and everything seems okay except
> that my tiger.state table is empty, which prevents geocoding.
> >    Notwithstanding the import step, and the adress normaliser, it seems
> to
> boil down to a large query in the function tiger.geocode_address().
> >    I would be delighted to have some pointers on the design of the
> postgis_tiger_geocoder extension.
> >    In perticular, I don't understand the address standardizer business at
> all (yeah, I found some doc, no, I don't understand it well)
> >    Many thanks for help,
> >    Cheers,
> >    Rémi-C
> Just adding to what Steve has already said.
> Don't try to use the postgis tiger geocoder as a model of how to set up a
> geocoder.
> The structure of it is very tied to how the US Census Tiger data is setup.
> The irony is because it is setup like US Census, I think people try to use
> it for more than a geocoder and I get bug reports on fields I ignored
> because they really aren't relevant as far as geocoding is concerned or not
> relevant to me (in other moneywise ways).  I can't blame them since I do
> use
> it myself on other projects for more than just geocoding.  E.g. census
> tract
> work or just joining with the states, counties etc when I need a county
> list.
> If I had started from scratch instead of inheriting the code this is not
> how
> I would do it.
> But without enough traction of people willing to devote time/fund  a more
> generic geocoder, the more globally useful solution will not go anywhere.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160617/720037c1/attachment.html>
