[postgis-devel] Raster tile size impact results
Pierre Bails bails at getredbird.com
Mon Jun 20 02:49:06 PDT 2016
Hi all,
I'm looking for get all pixel's value in a raster insert thanks to
raster2pgsql intersect by a polygon.
Nevertheless, there are some things that I don't understand: depends on
tile size, I don't have the same result... The error between 2 raster is
also correlate to the pixel size (I assume it's due to the pixel number).
Can you explain me how the tile size can influence the final result ?
*Here is the query :*
SELECT DISTINCT SUM((px).val)
FROM(
  SELECT *
  FROM  mns INNER JOIN
 st_setsrid(st_geomfromgeojson('{"type":"Polygon","coordinates":[[[x,y],
[x,y],[x,y] ]]}'), 4326) as geom on ST_Intersects(mns.rast, geom)
) AS clip, ST_PixelAsCentroids (ST_Clip(clip.rast, clip.geom),1) AS px;
*DSM px size 70cm: *
raster2pgsql -a -t 250x250 -s 4326 -F pathToDSM.tiff dsmTable (result: 46
347 846)
raster2pgsql -a -t 50x50 -s 4326 -F pathToDSM.tiff dsmTable     (result: 46
382 873)
Difference: 35027
*DSM px size 20cm : *
567 505 888)
raster2pgsql -a -t 50x50 -s 4326 -F pathToDSM.tiff dsmTable      (result: 596
897 610)
Difference: 29 391 722
If we considere 250x250's result as reference, there is a difference of
0.07% in the first case, and 5% in the second. If the polygon
area increases, the error rate increases.
Thank you,
Pierre
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160620/7882d5b7/attachment.html>
