[postgis-devel] Is posible to use function lwgeom_to_geojson in another c fuctions
Jan Michálek godzilalalala at gmail.com
Sat Jun 25 05:02:29 PDT 2016
You are using postgrest on some bigger data with spatial parts? I tried it
few days ago and on many features it was pretty slow... But i didn`t make
any tuning, maybe is there space for optimaliyation for my usecase.
2016-06-25 13:43 GMT+02:00 Nicklas Aven <nicklas.aven at jordogskog.no>:
> Just a comment.
> With all the new json functions in PostgreSQL this is very easy to do
> directly in sql too. I think it is fairly efficient too. I use it in
> production to export complete geojson through postgrest.
> I have thougt about if we could get rid of json-c dependency and use
> postgresql functionality instead.
> Building json with jsonb, I guess is a lot faster than dealing with text
> strings.
> /Nicklas
> Skickat från min Sony Xperia™-smartphone
> ---- Jan Michálek skrev ----
> > Hello
> > I need a advice about this problem
> > I'm trying to write some C fuction for making geojson as aggregate from
> records as full regular geojson with properties.
> > I tried to use function lwgeom_to_geojson inside my code.
> > something like this
> >                 case JSONTYPE_GEOM: //je;
> >                         LWGEOM *lwgeom;
> >                         lwgeom = lwgeom_from_gserialized(
> >                              (GSERIALIZED*)DatumGetPointer(val)
> >                         outputstr = lwgeom_to_geojson(lwgeom, 0, 0,
> false);
> >                         escape_json(result, outputstr);
> >                         pfree(outputstr);
> >                         break;
> > I have
> > #include "liblwgeom.h"
> > And I`m able to compile this. But if I try use function in postgre, it
> get me an error
> > ERROR:  could not load library "/usr/lib/postgresql/jelejson.so":
> /usr/lib/postgresql/jelejson.so: undefined symbol: lwgeom_to_geojson.
> > What i should do? Is posible to use this function like this?
> > Thanks Je;
> > Jelen
> > Starší čeledín datovýho chlíva
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
Jelen
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160625/ebe47ed4/attachment.html>
