[postgis-devel] Building Postgris on Solaris 11
Andrew Watkins andrew at dcs.bbk.ac.uk
Thu Jun 30 08:28:02 PDT 2016
Hello folks,
Beening battling my way through Postgis on Solaris and I am getting
close but still getting errors. Here is the relevant information and any
pointers:
postgis-2.2.2# ./configure CC=/opt/studio12u1/bin/cc CFLAGS="-m64
-DNAN=\"(0.0/0.0)\"" CPPFLAGS=-m64 CXXFLAGS=-m64 LDFLAGS="-m64
-L/usr/local/postgres/pgdg/lib/64 -L/usr/local/postgres/geos/lib
-L/usr/local/postgres/proj4/lib" \
--with-pgconfig=/usr/local/postgres/pgdg/bin/64/pg_config \
--with-geosconfig=/usr/local/postgres/geos/bin/geos-config \
--with-gdalconfig=/usr/local/postgres/gdal/bin/gdal-config \
     --with-projdir=/usr/local/postgres/proj4
   PostGIS is now configured for i386-pc-solaris2.11
  -------------- Compiler Info -------------
   C compiler:           /opt/studio12u1/bin/cc -m64 -DNAN="(0.0/0.0)"
   SQL preprocessor:     /usr/gcc/4.5/bin/cpp -traditional-cpp -w -P
  -------------- Dependencies --------------
   GEOS config: /usr/local/postgres/geos/bin/geos-config
   GEOS version:         3.5.0
   GDAL config: /usr/local/postgres/gdal/bin/gdal-config
   GDAL version:         2.1.0
   PostgreSQL config: /usr/local/postgres/pgdg/bin/64/pg_config
   PostgreSQL version:   PostgreSQL 9.5.3
   PROJ4 version:        49
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.2
   JSON-C support:       yes
   PCRE support:         no
   PostGIS debug level:  0
   Perl:                 /usr/bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
   SFCGAL support:       disabled
   Address Standardizer support:       disabled
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:
   dblatex:
   convert:
   mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
# make
/usr/bin/perl ../utils/postgis_proc_set_search_path.pl postgis.sql
UNUSED > postgis_proc_set_search_path.sql
/usr/gcc/4.5/bin/cpp -traditional-cpp -w -P -I../libpgcommon
legacy.sql.in | grep -v '^#' | \
/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.2'g" > legacy.sql
/usr/bin/perl ../utils/create_undef.pl legacy.sql 95 > uninstall_legacy.sql
legacy_minimal.sql.in | grep -v '^#' | \
legacy_minimal.sql
legacy_gist.sql.in | grep -v '^#' | \
legacy_gist.sql
make[1]: Leaving directory `/tmp/postgis-2.2.2/postgis'
---- Making all in regress
make[1]: Entering directory `/tmp/postgis-2.2.2/regress'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/tmp/postgis-2.2.2/regress'
---- Making all in raster
make[1]: Entering directory `/tmp/postgis-2.2.2/raster'
make -C rt_core
make[2]: Entering directory `/tmp/postgis-2.2.2/raster/rt_core'
/opt/studio12u1/bin/cc -m64 -DNAN="(0.0/0.0)"  -KPIC -DPIC
-I../../liblwgeom -I/usr/local/postgres/gdal/include
-I/usr/local/postgres/proj4/include -I/usr/local/postgres/geos/include
-c -o rt_util.o rt_util.c
"/usr/local/postgres/gdal/include/ogr_core.h", line 415: warning:
enumerator value overflows INT_MAX (2147483647)
"/usr/local/postgres/gdal/include/ogr_core.h", line 416: warning:
"/usr/local/postgres/gdal/include/ogr_core.h", line 417: warning:
"/usr/local/postgres/gdal/include/ogr_core.h", line 418: warning:
"/usr/local/postgres/gdal/include/ogr_core.h", line 419: warning:
"/usr/local/postgres/gdal/include/ogr_core.h", line 420: warning:
"/usr/local/postgres/gdal/include/ogr_core.h", line 421: warning:
"librtcore.h", line 151: warning: macro redefined: __attribute__
"librtcore.h", line 245: syntax error before or at: (
"librtcore.h", line 244: function cannot return function or array
"librtcore.h", line 245: warning: function prototype parameters must
have types
"librtcore.h", line 245: warning: syntax error:  empty declaration
"/usr/include/assert.h", line 23: syntax error before or at: (
"/usr/include/assert.h", line 23: function cannot return function or array
"rt_util.c", line 142: warning: statement not reached
"rt_util.c", line 173: warning: statement not reached
cc: acomp failed for rt_util.c
make[2]: *** [rt_util.o] Error 2
make[2]: Leaving directory `/tmp/postgis-2.2.2/raster/rt_core'
make[1]: *** [corelib] Error 2
make[1]: Leaving directory `/tmp/postgis-2.2.2/raster'
make: *** [all] Error 1
I have tried it with gcc but I get the same error.
Thanks,
Andrew
Andrew Watkins * Birkbeck, University of London * Computer Science *
* http://notallmicrosoft.blogspot.com *
* UKOUG Systems SIG Chair *
* UKOUG Tech committee *
* tel: 020 7631 6720 *
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160630/35326ef1/attachment.html>
