[postgis-devel] transifex complaining about pot files
George Silva georger.silva at gmail.com
Sun Mar 6 12:01:17 PST 2016
i got the email and i havent updated the file.
ill see if i can fix it.
On Mar 6, 2016 4:30 PM, "Sandro Santilli" <strk at keybit.net> wrote:
> Did anyone recently update the source .pot files in an incompatible way ?
> Forwarding a couple of mails just received from Transifex
> (dunno who else receives these mails)
> ----- Forwarded message from Transifex <admin at transifex.com> -----
> Date: Sun, 06 Mar 2016 19:10:21 -0000
> From: Transifex <admin at transifex.com>
> To: strk at keybit.net
> Subject: [Transifex] Automatic update of the source file of
> introduction.xml.pot in PostGIS failed
> Hi Sandro Santilli,
> We have not been able to update the source file for the resource
> introduction.xml.pot[1] of the project PostGIS[2].
> The URL we used to update the source file from was
> https://raw.githubusercontent.com/postgis/postgis/svn-trunk/doc/po/templates/introduction.xml.pot
> The exact error we encountered was:
> 'ascii' codec can't encode character u'\xe9' in
> position 4100: ordinal not in range(128)
> [1]:
> https://www.transifex.com/_/resources/ajax/postgis/postgis/edit/introductionxmlpot/
> [2]: https://www.transifex.com/postgis/postgis/
> The Transifex Robot
> https://www.transifex.com/settings/notices/
> ----- End forwarded message -----
> Date: Sun, 06 Mar 2016 19:11:28 -0000
> release_notes.xml.pot in PostGIS failed
> Hi Sandro Santilli,
> release_notes.xml.pot[1] of the project PostGIS[2].
> https://raw.githubusercontent.com/postgis/postgis/svn-trunk/doc/po/templates/release_notes.xml.pot
> position 14979: ordinal not in range(128)
> [1]:
> https://www.transifex.com/_/resources/ajax/postgis/postgis/edit/release_notesxmlpot/
> The Transifex Robot
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160306/d72cdab1/attachment.html>
