[postgis-devel] transifex complaining about pot files
George Silva georger.silva at gmail.com
Mon Mar 7 08:58:20 PST 2016
Hello everyone.
I'm still receiveing tons of emails.
I have looked into PostGIS Github repository and there are no significant
changes in the source files. Transifex started to fail parsing unicode on
some of our files. For example "Jorge Arévalo", on introduction.xml.
I'll check with transifex if there is some sort of configuration that we
can have or known bug. Very weird that after so much time this starts to
fail for no particular reason.
I'll keep you posted.
On Sun, Mar 6, 2016 at 5:01 PM, George Silva <georger.silva at gmail.com>
wrote:
> i got the email and i havent updated the file.
> ill see if i can fix it.
> On Mar 6, 2016 4:30 PM, "Sandro Santilli" <strk at keybit.net> wrote:
>> Did anyone recently update the source .pot files in an incompatible way ?
>> Forwarding a couple of mails just received from Transifex
>> (dunno who else receives these mails)
>> ----- Forwarded message from Transifex <admin at transifex.com> -----
>> Date: Sun, 06 Mar 2016 19:10:21 -0000
>> From: Transifex <admin at transifex.com>
>> To: strk at keybit.net
>> Subject: [Transifex] Automatic update of the source file of
>> introduction.xml.pot in PostGIS failed
>> Hi Sandro Santilli,
>> We have not been able to update the source file for the resource
>> introduction.xml.pot[1] of the project PostGIS[2].
>> The URL we used to update the source file from was
>> https://raw.githubusercontent.com/postgis/postgis/svn-trunk/doc/po/templates/introduction.xml.pot
>> The exact error we encountered was:
>> 'ascii' codec can't encode character u'\xe9' in
>> position 4100: ordinal not in range(128)
>> [1]:
>> https://www.transifex.com/_/resources/ajax/postgis/postgis/edit/introductionxmlpot/
>> [2]: https://www.transifex.com/postgis/postgis/
>> The Transifex Robot
>> https://www.transifex.com/settings/notices/
>> ----- End forwarded message -----
>> Date: Sun, 06 Mar 2016 19:11:28 -0000
>> release_notes.xml.pot in PostGIS failed
>> Hi Sandro Santilli,
>> release_notes.xml.pot[1] of the project PostGIS[2].
>> https://raw.githubusercontent.com/postgis/postgis/svn-trunk/doc/po/templates/release_notes.xml.pot
>> position 14979: ordinal not in range(128)
>> [1]:
>> https://www.transifex.com/_/resources/ajax/postgis/postgis/edit/release_notesxmlpot/
>> The Transifex Robot
>> --strk;
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-devel
George R. C. Silva
Sigma Geosistemas LTDA
http://www.sigmageosistemas.com.br/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160307/a2e5adca/attachment.html>
