[postgis-devel] build 2.2x version number ?
Brian M Hamlin maplabs at light42.com
Fri Mar 18 11:19:27 PDT 2016
please see   https://trac.osgeo.org/postgis/ticket/3506#ticket
I believe it is not VERSION, but that is a secondary effect from
postgis.sql being empty before it fails
On Fri, 18 Mar 2016 10:23:46 -0700, Brian M Hamlin  wrote:
       Hi - I have the 2.2 branch on Ubuntu 1404  -- the build is
failing.. Am I missing a step here ?
I../libpgcommon postgis.sql.in | grep -v '^#' | \
/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.2'g" > postgis.sql
/bin/sh: 1: I../libpgcommon: not found
/usr/bin/perl ../utils/create_undef.pl postgis.sql 94 > uninstall_postgis.sql
/usr/bin/perl ../utils/postgis_proc_upgrade.pl postgis.sql UNUSED >
postgis_upgrade.sql.in
Unable to locate target new version number in postgis.sql
Makefile:161: recipe for target 'postgis_upgrade.sql.in' failed
make[1]: *** [postgis_upgrade.sql.in] Error 255
make[1]: *** Deleting file 'postgis_upgrade.sql.in'
make[1]: Leaving directory '/home/shared/srcs_i7d/postgis_22_branch/postgis'
GNUmakefile:16: recipe for target 'all' failed
make: *** [all] Error 1
here is the configure output:
  PostGIS is now configured for x86_64-unknown-linux-gnu
 -------------- Compiler Info -------------
  C compiler:           gcc -g -O2
  SQL preprocessor:
 -------------- Dependencies --------------
  GEOS config:          /usr/local/bin/geos-config
  GEOS version:         3.5.1
  GDAL config:          /usr/local/bin/gdal-config
  GDAL version:         1.11.0
  PostgreSQL config:    /usr/bin/pg_config
  PostgreSQL version:   PostgreSQL 9.4.6
  PROJ4 version:        48
  Libxml2 config:       /usr/bin/xml2-config
  Libxml2 version:      2.9.1
  JSON-C support:       yes
  PCRE support:         yes
  PostGIS debug level:  0
  Perl:                 /usr/bin/perl
 --------------- Extensions ---------------
  PostGIS Raster:       enabled
  PostGIS Topology:     enabled
  SFCGAL support:       disabled
  Address Standardizer support:       enabled
 -------- Documentation Generation --------
  xsltproc:             /usr/bin/xsltproc
  xsl style sheets:     /usr/share/xml/docbook/stylesheet/nwalsh
  dblatex:
  convert:              /usr/bin/convert
  mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/postgis-devel
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160318/4c81fc02/attachment.html>
