[postgis-devel] Static Analysis
Paul Ramsey pramsey at cleverelephant.ca
Fri May 6 11:55:29 PDT 2016
OK, thanks all, I've asked Crunchy to go ahead and put the wheels in motion.
Dreading that first report,
P
On Fri, May 6, 2016 at 2:33 AM, Nicklas Aven <nicklas.aven at jordogskog.no> wrote:
> Interesting things. I want to dp my share of the clean up work.
> I guess I will learn a lot from that.
> Will most of the issues be isolated to source files, or special functions or
> will it be more about keeping things conseqent over the whole code base?
> /Nicklas
> Skickat från min Sony Xperia™-smartphone
> ---- Even Rouault skrev ----
> Le vendredi 06 mai 2016 10:55:50, Mark Cave-Ayland a écrit :
>> On 05/05/16 19:06, Paul Ramsey wrote:
>> > Hey Devs,
>> > Are we interested in receiving static analysis reports (Coverity) on
>> > the PostGIS code base?
>> > The folks at CrunchyData are willing to stick-handle the bureaucracy
>> > around getting Coverity account for the project and a system set up to
>> > regularly pass the PostGIS code base through Coverity static analysis.
>> > Coverity provides free (as in beer) accounts for open source projects,
>> > so the actual Coverity "account" would be the PostGIS project's and
>> > the PSC would control it.
>> > Anyways, other than providing an annoying list of things we should do
>> > (gah!) I see no downside to having some more information on our code
>> > cleanliness/security. Unlike the transifex stuff, there'd be no
>> > dependencies on a foreign system, since if Coverity ever shut off our
>> > access we'd be no worse off than we are right now.
>> > Thoughts?
>> Definitely! I suspect that there will be a number of things to check
>> after the first scan which may take some time. Note that Coverity does
>> produce false positives, so perhaps some thought should be given to as
>> to whether we should aim for a "clean" scan to the point where we can
>> add annotations to the code for cases like these.
> We have gone through the Coverity route for GDAL. Dealing with the results
> of
> the first scan is likely to be painful (took months to clear the > 1300
> initial
> stock). There are some false positives, but not that much (10% ?). In
> general
> you get false positives in portion of the code where the logic is convoluted
> and you can get rid of most of them by simplifying the code a bit, or adding
> extra conditions, and making it more obvious, including for humans.
> For real false positives, you can add the following annotation before the
> line
> /* coverity[name_of_the_violated_rule] */
> The largest occurence in GDAL code base is /* coverity[tainted_data] */ ,
> that
> is due to using the value of an environment variable with no or little
> checking. Likely not going to affect PostGIS.
> We've also used Clang Static Analyzer. To be honest, it is far less powerful
> than Coverity and has a high rate of false positives, and reworking the code
> to make it happy can be really hard sometimes. It did uncover a couple of
> things other tools didn't find though but the rate time invested to
> investigate
> reports / bug founds is prettly low. If you want to give it a try, I'd
> recommend only using it after cleaning all Coverity warnings, so as to limit
> the number of things to look at.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
