[postgis-devel] ST_PointOnSurface not for PolygonZ?
Tom van Tilburg
tom.van.tilburg at gmail.com
Wed Nov 2 08:24:11 PDT 2016
Manual says: "This function supports 3d and will not drop the z-index."
This indeed works as per documentation example:
SELECT ST_AsEWKT(ST_PointOnSurface(ST_GeomFromEWKT('LINESTRING Z(0 5 1, 0 0
1, 0 10 2)')));
Returns: "POINT(0 0 1)"
This doesn't:
SELECT ST_AsEWKT(ST_PointOnSurface(ST_GeomFromEWKT('POLYGON Z((14 14 10,20
10 150,34 6 25,14 14 10))')))
Returns: "POINT(18 12)"
Inspired by:
http://gis.stackexchange.com/questions/216212/how-to-create-points-grid-on-a-3d-surface-with-geometry-polygonz-in-postgis
and:
http://gis.stackexchange.com/questions/201161/postgis-st-pointonsurface-and-st-centroid-dropping-z
I guess GEOS is just not capable of doing this, but the documentation is
not clear about that and implies that PolygonZ would work just as
LinestringZ would work.
Best,
Tom
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20161102/d1595c36/attachment.html>
