[postgis-devel] please review my assumption about segmentize and bbox
Darafei "Komяpa" Praliaskouski me at komzpa.net
Sat Nov 12 03:19:29 PST 2016
ST_Extent('SRID=4326;LINESTRING(-73 40, 53 27)'::geography::geometry) = BOX(-73
27,53 40)
ST_Extent(ST_Segmentize('SRID=4326;LINESTRING(-73 40, 53
27)'::geography,100)::geometry) = BOX(-73 27,53 56.2529232769426)
In planar geometry your assumption should be valid, though.
сб, 12 нояб. 2016 г. в 14:12, Sandro Santilli <strk at kbt.io>:
> Doing topology loading tests I found time is spent to update
> the bounding box of faces whenever their edges are split.
> Following the train of thougths I arrived at asking myself:
> Is it possible that adding vertices in a segment could ever change
> the segment bounding box ?
> My answer is NO.
> Could you please review and confirm ?
> If my answer is correct, not only we can speed up topology loading,
> but also (for example) the ST_Segmentize function, which is currently
> *dropping* a cached BBOX value to be on the safe side (ie: to not
> answer that question).
> Math proofs welcome :)
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20161112/987608e1/attachment.html>
