[postgis-devel] PostGIS dependency CharLS was retired in EPEL
Even Rouault even.rouault at spatialys.com
Wed Oct 19 13:38:34 PDT 2016
I suspect the issue is rather with GDAL. CharLS is an optional (and not very
popular as far as I know) dependency of GDAL. GDAL can certainly be rebuilt
without it.
Even
> Hi folks,
> I was building postgis 2.2.3 today, when things broke strangely during
> dependency processing:  "No package CharLS available".
> I did some research, and apparently this dependent library was orphaned
> today, with this message:
> 2016-10-19: Retired orphaned package, because it was orphaned for
> more than six weeks.
> You can see that info here as well:
> http://pkgs.fedoraproject.org/cgit/rpms/CharLS.git/
> So, one of postgis's dependencies is no longer in EPEL.
> I checked on the #epel channel in Freenode, and they had this to say:
> "If you're a Fedora packager, you can request that you become the
> maintainer of that package and that it be un-retired.  It was just retired
> today so that can be undone easily.  But of course it can only be undone if
> someone actually wants to maintain it."
> So... I'm not really sure what to do here.  I can build CharLS myself, but
> that sounds like a big ask for anyone using PostGIS on EL6.  It's probably
> worth asking if anyone wants to stand up and maintain the CharLS package on
> EL6?  Or, could the CharLS dependency be removed?
> Thanks!
>   -John
http://www.spatialys.com
