[postgis-devel] ST_AsGeobuf
Paul Norman penorman at mac.com
Mon Sep 12 01:46:39 PDT 2016
On 9/12/2016 12:59 AM, Björn Harrtell wrote:
> Hi devs,
> I've been working on a new output format function called ST_AsGeobuf
> these last months. Its purpose is to serialize full query output into
> the binary format Geobuf containing both geometry and attributes. The
> implementation is tracked by:
> https://trac.osgeo.org/postgis/ticket/3599
> https://git.osgeo.org/gogs/postgis/postgis/pulls/4 or alternatively
> https://github.com/bjornharrtell/postgis/tree/asgeobuf5
> Geobuf is a binary format specified by Mapbox that can represent
> similar data and structure as GeoJSON but is more compact and is
> faster encode and decode. You can read more about Geobuf at
> https://github.com/mapbox/geobuf which also serves as the reference
> implementation to decode at a browser client side.
> Geobuf is in turn based on Googles protobuf standard which I think is
> similar to a binary XML. My implementation uses the general purpose
> library protobuf-c to simplify the encoding.
> I hope to be able use this work as a base to also implement support
> for vector tiles as specified by Mapbox which is also based on protobuf.
> I think the implementation is ready for review and testing. If you
> have any interest in Geobuf or vector tiles output support I'd
> appreciate review and/or test result feedback.
The MapBox geobuf page states "Note that the encoding schema is not
stable yet". Is it premature to put this in PostGIS?
