[postgis-devel] [postgis] 01/01: Update pgversions to require PostgreSQL 9.2 or newer.
Regina Obe lr at pcorp.us
Tue Sep 27 16:02:44 PDT 2016
No PostGIS 2.3 is not compatible with PostgreSQL 9.1.
As I recall I think it compiles fine against (without our change in
configure), but we dropped support for it since
1) it is EOL this month
(https://www.postgresql.org/docs/9.1/static/release-9-1-23.html )
2) Some of the raster tests started failing with recent raster changes.
Sorry about that.   I've corrected the readme.
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf
Of Markus Wanner
Sent: Tuesday, September 27, 2016 3:57 PM
To: Sebastiaan Couwenberg <sebastic at xs4all.nl>; PostGIS Development
Discussion <postgis-devel at lists.osgeo.org>
Cc: pkg-grass-devel at lists.alioth.debian.org
Subject: Re: [postgis-devel] [postgis] 01/01: Update pgversions to require
Hello Bas, hello PostGIS devs,
On 09/27/2016 07:50 PM, Sebastiaan Couwenberg wrote:
> PostGIS is compatible with PostgreSQL 9.1 and above.
That's what I thought as well, but configure.ac has a different opinion.
@upstream: could you please clarify: is PostGIS 2.3 supposed to be
compatible against PostgreSQL 9.1?
Kind Regards
Markus
