[postgis-devel] regress test core dumps on Solaris 11
Dechaux Eric CEN (BCQ STIG) eric.dechaux at gendarmerie.interieur.gouv.fr
Mon Aug 7 03:13:29 PDT 2017
Hello,
I am building postgis 2.3.4 on Solaris 11.3 SPARC and x86_64. I have no
issue with postgresql 9.4.12 an 9.6.3 however on 9.5.7 the postgresql
server coredumps during the make check regress step :
PATH is
/appli/stig/11.3.2017-08-07/pgsql/9.5.7/bin:/appli/stig/11.3.2017-08-07/pgsql/9.5.7/bin:/appli/stig/11.3.2017-08-07/bin:/usr/gnu/bin:/usr/gcc/5/bin:/usr/bin
Checking for shp2pgsql ... found
Checking for pgsql2shp ... found
Checking for raster2pgsql ... found
TMPDIR is /tmp/pgis_reg
Creating database 'postgis_reg'
Loading PostGIS into 'postgis_reg'
Loading Raster into 'postgis_reg'
PostgreSQL 9.5.7 on sparc-sun-solaris2.11, compiled by gcc (GCC) 5.4.0,
64-bit
   Postgis 2.3.3 - r15473 - 2017-08-07 07:20:29
   scripts 2.3.3 r15473
   raster scripts 2.3.3 r15473
   GEOS: 3.6.2-CAPI-1.10.2 4d2925d6
   PROJ: Rel. 4.9.3, 15 August 2016
   GDAL: GDAL 2.2.1, released 2017/06/23
Running tests
  check_gdal .. ok
  load_outdb ... ok
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  box3d .. ok
  rt_addband .. failed (diff expected obtained: /tmp/pgis_reg/test_8_diff)
  rt_band .. failed (diff expected obtained: /tmp/pgis_reg/test_9_diff)
  rt_tile .. failed (diff expected obtained: /tmp/pgis_reg/test_10_diff)
  rt_dimensions .. failed (diff expected obtained:
/tmp/pgis_reg/test_11_diff)
  rt_scale .. failed (diff expected obtained: /tmp/pgis_reg/test_12_diff)
  rt_pixelsize .. failed (diff expected obtained:
/tmp/pgis_reg/test_13_diff)
  rt_upperleft .. failed (diff expected obtained:
/tmp/pgis_reg/test_14_diff)
  rt_rotation .. failed (diff expected obtained: /tmp/pgis_reg/test_15_diff)
  rt_georeference .. failed (diff expected obtained:
/tmp/pgis_reg/test_16_diff)
  rt_set_properties .. failed (diff expected obtained:
/tmp/pgis_reg/test_17_diff)
  rt_isempty .. failed (diff expected obtained: /tmp/pgis_reg/test_18_diff)
  rt_hasnoband .. failed (diff expected obtained:
/tmp/pgis_reg/test_19_diff)
  rt_metadata .. failed (diff expected obtained: /tmp/pgis_reg/test_20_diff)
  rt_rastertoworldcoord .. failed (diff expected obtained:
/tmp/pgis_reg/test_21_diff)
Only the rt_addband step coredumps, other tests are failing because the
progress instance is restarting.
The stack trace is :
$ pstack core
core 'core' of 29251:
/appli/stig/11.3.2017-08-07/pgsql/9.5.7/bin/postgres -D /tmp/HayW8S.sh
  ffffffff7da852d4 memcpy%sun4v-hwcap4 (0, ffffffff7fff9fe0,
ffffffff7fff9fd0, 10098cf98, 0, 10098cf94) + 6c0
  00000001001f31f0 heap_form_tuple (10098cf68, ffffffff7fff9fe0,
ffffffff7fff9fd0, 2, 18, 10098cf68) + 140
  ffffffff72959a24 RASTER_dumpAsPolygons (10087f258, ffffffff7fff9751,
0, 10, 0, 10) + 85c
  000000010036abc0 ExecMakeFunctionResult (10087f1e8, 10087f088,
100901d38, 100901e50, 1, 10087f258) + 1f4
  0000000100367bf8 ExecEvalFieldSelect (10087f198, 10087f088, 100901d38,
100901e50, 0, 2) + 1c
  000000010036d61c ExecProject (100901e00, ffffffff7fffa46c, 10087f088,
100901d20, 100901d38, 0) + 14c
  000000010036dad8 ExecScan (1008801e0, 100384214, 10038420c, 0,
10087ef78, 10087f088) + 1f8
  0000000100365aac ExecProcNode (10087ef78, 2, 10087eae8, 100901c40,
100860710, 0) + 214
  000000010036228c standard_ExecutorRun (10087ea58, 1, 0, 100400, 0,
10087ee68) + a4
  0000000100489f74 PortalRunSelect (100860d78, 1, 0, 1008efdb8,
10087ea58, 100860d78) + 1d0
  000000010048b5a8 PortalRun (100860d78, 7fffffffffffffff, 1, 1007b3ad8,
1007b39c8, 0) + 34c
  0000000100487c88 PostgresMain (1007763e8, 1008efdb8, 2, 1007b7170,
100860d78, 1007b7060) + 1aac
  00000001005de0b8 ServerLoop (100758460, 10070e000, 100000, 100186ed8,
100000, 1007783c0) + 13b8
  0000000100421648 PostmasterMain (3, 100755fb0, 100000, 100000,
10073f000, 100400) + 1504
  00000001005df584 main (3, ffffffff7ffff758, 64, 100755fb0, 100400,
100750570) + 7f8
  00000001001ebe74 _start (0, 0, 0, 0, 0, 0) + 7c
Any idea why this test would crash only with this postgresql version ?
Thanks
Eric DECHAUX
BCQ / STIG
01 58 66 57 57
Ce message électronique et tous les fichiers attachés qu'il contient sont confidentiels et destinés exclusivement à l'usage de la personne à laquelle ils sont adressés. Si vous avez reçu ce message par erreur, merci de le retourner à son émetteur. La publication, l'usage, la distribution, l'impression ou la copie non autorisée de ce message et des attachements qu'il contient sont strictement interdits.
En cas d'urgence, composez le 17 ou le 112.
Afin de contribuer au respect de l'environnement, merci de n'imprimer cet e-mail qu'en cas de necessite.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual to whom it is addressed. If you have received this email in error please send it back to the person that sent it to you. Unauthorized publication, use, dissemination, forwarding, printing or copying of this email and its associated attachments is strictly prohibited.
In case of emergency, dial number 17 or 112.
To contribute to the environmental protection, please print this e-mail only if necessary.
