[postgis-devel] Create a new data type for PostGIS in C
Fabiana Zioti fabi_zioti at hotmail.com
Thu Aug 17 10:47:06 PDT 2017
Hello,
I developed some basic extensions for PostgreSQL to study. The extensions contained input and output functions, operators, index (GiST), among others.
Now I would like to create a new data type for PostGIS, but I have some difficulties. Here's what I've done so far:
struct trajectory_elem
  int32 id;
  Timestamp time_obj;
  GSERIALIZED *geom_elem;       /* Geometry Object */
#define DatumGetTrajectoryElem(X)      ((struct trajectory_elem*) PG_DETOAST_DATUM(X))
#define PG_GETARG_TRAJECTELEM_TYPE_P(n)  DatumGetTrajectoryElem(PG_GETARG_DATUM(n))
#define PG_RETURN_TRAJECTELEM_TYPE_P(x)  PG_RETURN_POINTER(x)
PG_FUNCTION_INFO_V1(trajectory_elem);
Datum
trajectory_elem(PG_FUNCTION_ARGS)
  int32 id = PG_GETARG_INT32(0);
  Timestamp timestamp = PG_GETARG_TIMESTAMP(1);
  GSERIALIZED *geom = (GSERIALIZED*)PG_DETOAST_DATUM(PG_GETARG_DATUM(2));
  LWGEOM *lwgeom = lwgeom_from_gserialized(geom);
  struct trajectory_elem *trje = (struct trajectory_elem *) palloc(sizeof(struct trajectory_elem));
  size_t size;
  /*elog(NOTICE, "trajectory_elem called");*/
  if (lwgeom_is_empty(lwgeom) || lwgeom->type != POINTTYPE)
    elog(NOTICE, "trajectory_elem is NULL, or type is not correct");
  PG_RETURN_NULL();
  trje->id = id;
  trje->time_obj = timestamp;
  trje->geom_elem = gserialized_from_lwgeom(lwgeom, &size);
  elog(NOTICE, "trajectory_elem finish");
  /* Then call free_if_copy on the *varlena* structures you originally get as arguments */
  lwgeom_free(lwgeom);
  PG_FREE_IF_COPY(geom, 0);
  PG_RETURN_TRAJECTELEM_TYPE_P(trje);
I also imprinted the output function using lwgeom_to_hexwkb(lwgeom, WKB_EXTENDED, &size);
But in PG_RETURN the connection is closed.
It is wrong the way I'm programming the UDT for PostGIS?
Am I missing too many details? Would you have any examples of creating a new type of data for PostGIS?
Thanks in advance !! (and Sorry for the english)
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170817/0f2c89ae/attachment.html>
