[postgis-devel] PSC Vote: Change PostGIS library name to drop the minor
Greg Troxel gdt at lexort.com
Wed Aug 30 04:53:52 PDT 2017
"Darafei \"Komяpa\" Praliaskouski" <me at komzpa.net> writes:
> I've just finished my upgrade to Postgres 10.
> Fixing PostGIS library name would have made the upgrade cleaner and save
> some fiddling with symlinks.
> Although, same problem is there for pgrouting, so you're getting used to it
> https://gist.github.com/Komzpa/994d5aaf340067ccec0e
I don't understand why this is necessary.   Upgrading postgresql means
that you then need to install a version of postgis that is built against
the new postgresql version.   When I do this in pkgsrc, there is no need
to even know about symlinks to library versions.
Is the postgis package you are using somehow not tied to a postgresql
version?
Are you doing something other than dump/restore?
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170830/ed26170c/attachment.sig>
