[postgis-devel] [PostGIS] #3949: Infinite (?) loop in distance calculation
Paul Ramsey pramsey at cleverelephant.ca
Fri Dec 22 05:51:20 PST 2017
At the suggestion of Darafei I have made a PR for initial review
before doing a merge and commit.
https://github.com/postgis/postgis/pull/175
On Fri, Dec 22, 2017 at 5:35 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> So, I now have tree distance code that seems to work, thanks to this
> little bug, which caused me to find the error in my tree code. I'd
> given up on it, figured the tree approach was a dead end.
> https://github.com/pramsey/postgis/tree/svn-trunk-distance
> In very limited testing, I see it running quite a bit faster (100x)
> than the existing code on large objects, but slightly slower on small
> objects (10%). I was thinking on merging it to trunk but as a
> completely independent function for now (ST_DistanceRectTree()) so
> that it can be tested and the functional limits of it determined. Then
> we can discuss how we want to integrate it into generic ST_Distance(),
> maybe with a object size test, or maybe as a cached approach (skipping
> the tree built step in cases with repeated inputs would probably be a
> win).
> Thoughts?
> P
> On Fri, Dec 22, 2017 at 4:15 AM, PostGIS <trac at osgeo.org> wrote:
>> Comment (by nicklas):
>>  I agree.
>>  But worst case is different for different methods.
>>  The example Paul provided here is among the worst cases for the algorithm
>>  we use now (when bboxes doesn't overlap, then it falls back to brute
>>  force)
>>  If the shoreline of both geometries would have been convex it would have
>>  been quite a lot faster, but now one is concave and all points in the
>>  concave part needs to be tested more or less.
>>  So for this case that is a pain for that algorithm it loses the battle
>>  with about 1.08 (79 sec vs 85 sec)
>>  But for the case with the same geometries further away it wins by using
>>  approx 0.04 of the time brute force method uses. And with the case when we
>>  turn the other side of the geometries against each other it wins by using
>>  approx 0.0005 of the brute force method.
>>  So in this case I think the 8 % worse result in some cases is ok. BUT, the
>>  problem is that it is unpredictable. Users will like Paul think that
>>  something is wrong.
>>  But we have lived with this code now since 2010 and I don't think there
>>  have been many posts on the list about that issue. But I have hit that
>>  wall a few times myself making queries much slower than I expect. And it
>>  can be very frustrating when testing a sample to get an idea of the query
>>  time and then it takes 100 times longer.
>> Ticket URL: <https://trac.osgeo.org/postgis/ticket/3949#comment:9>
>> PostGIS <http://trac.osgeo.org/postgis/>
>> The PostGIS Trac is used for bug, enhancement & task tracking, a user and developer wiki, and a view into the subversion code repository of PostGIS project.
