[postgis-devel] size_t: width and signedness of counters
Paul Norman penorman at mac.com
Sat Dec 30 12:53:26 PST 2017
On 12/27/2017 8:37 AM, Darafei "Komяpa" Praliaskouski wrote:
> Hi,
> On my weighted median PR Dan Baston asked why do I use size_t as
> loop/array index even though PostGIS point array size is limited to
> 32-bit:
> https://github.com/postgis/postgis/pull/176#discussion_r158592196
> I've brought that habit from maps.me <http://maps.me> development
> team. Maps.me is cross-compiled for a set of architectures of modern
> Android devices (from MIPS through ARMs to x86_64).
> size_t is convenient as counter/index variable because of:
>  - it's unsigned. Any -1 becomes large enough to trigger segfault,
> address sanitizer and any kind of static code validators.
>  - it's type returned by sizeof(). You can't safely have an array
> larger than largest possible sizeof(array) of your compiler. (By
> standard you may be limited to 65536 elements - I don't expect PostGIS
> to be working in 16 bit systems, and uint32_t as counter won't help
> there to store longer arrays anyway).
>  - it's aligned with system architecture, being 32bit on 32bit systems
> and 64bit on 64-bit systems. Adding/subtracting it from pointers don't
> normally require compiler to perform implicit type casting. This is
> not required by standard but it is this way in practice.
>  - after some time of adopting such arrangement you see size_t
> variable and immediately know it's a positive counter that might be
> used as array index. :)
> If you think this change causes problems, let me know.
> Could it be that we want this everywhere? :)
I've been in the habit of using size_t from C++, where it's what all the
STL size-related operators use, and thus what you get when you use auto.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20171230/9f0584f8/attachment.html>
