[postgis-devel] Recheck on Points broken
Regina Obe lr at pcorp.us
Tue Jan 3 10:53:04 PST 2017
Nope not 100% sure was just a guess based on what Robert Haas said and my assumption that we don't generate boxes for points?
I thought we don't cause it's just baggage, which means we are using the point where as in other cases it is a box distance.
I did try to put a sniffer on where it's measuring distance adist[i], bdist[i] around 396 but always got a backend crash.
https://git.postgresql.org/gitweb/?p=postgresql.git;a=blob;f=src/backend/executor/nodeIndexscan.c;h=3143bd94ec4499fba94b41693538b785c4b32e6c;hb=HEAD#l396
372 static int
373 cmp_orderbyvals(const Datum *adist, const bool *anulls,
374                 const Datum *bdist, const bool *bnulls,
375                 IndexScanState *node)
376 {
377     int         i;
378     int         result;
379
 380     for (i = 0; i < node->iss_NumOrderByKeys; i++)
381     {
382         SortSupport ssup = &node->iss_SortSupport[i];
383
 384         /*
385          * Handle nulls.  We only need to support NULLS LAST ordering, because
386          * match_pathkeys_to_index() doesn't consider indexorderby
387          * implementation otherwise.
388          */
389         if (anulls[i] && !bnulls[i])
390             return 1;
391         else if (!anulls[i] && bnulls[i])
392             return -1;
393         else if (anulls[i] && bnulls[i])
394             return 0;
395
 396         result = ssup->comparator(adist[i], bdist[i], ssup);
397         if (result != 0)
398             return result;
399     }
400
 401     return 0;
402 }
You will probably have much better luck since I was just fumbling my way thru the code.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Tuesday, January 03, 2017 10:00 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Recheck on Points broken
Are we 100% sure this is a float/double issue? The distance between two float boxes should always be *smaller* than the actual distance between two objects, since the float box extrema are always moved *away* from the original object when the float boxes are created. So from a "theoretical mechanics" perspective this shouldn't actually be the source of the problem.
>From a real world point-of-view, how could it still be the problem?
- maybe the box generation code has a short circuit for points which doesn't do the correct thing? Pretty sure it doesn't, but.
- something else?
P
On Tue, Jan 3, 2017 at 4:54 AM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
>> Anyrate if there is nothing that can be done about ensuring index
>> distance is always less or equal to actual distance
> I remember we were all happy about having *real* distance with a more recent PostgreSQL. If that's not the case (as the user reports) we should try to find a way to provide both mechanisms.
> Two different operators, maybe ?
> --strk;
We've already got two different operators.  We have <#> which doesn't use recheck and that's what I told the user to use, until we resolve this.
The thing is the <-> I think pretty much for all reasonable purposes returns the right order for points (and in fact in this case yields the same value and <-> I think in all cases it will).
So it's just the float4/float8 mess why it screws up and it Errors noisily in PostgreSQL land where we cannot control.
I hate telling people to if you have point / point use <#> and if you have others you can safely use  <->.  That's sooo unfriendly.
I think the best thing is just to not have point-point checks use recheck.  Can we do that easily? That's what PostgreSQL point/point does.
That way we don't fall into the PostgreSQL box trap of
"Hey -- how come your index distance is bigger than your computed distance.  What kind of monster are you? Screw you!"
Thanks,
Regina
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170103/dfbc3e27/attachment.html>
