[postgis-devel] Docs broken for other languages
Regina Obe lr at pcorp.us
Mon Jan 30 12:12:29 PST 2017
George,
I generated it from trunk.  It might have been before strk committed his changes though, so I'm regenerating.
Looks like strk committed his changes at 15300
And the
Br one for example is http://postgis.net/docs/manual-dev/postgis-br.html  r15296
So  I think it just missed his commit.
Anyway should be rebuilt in about 15 minutes.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of George Silva
Sent: Monday, January 30, 2017 11:39 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Docs broken for other languages
Regarding the README, I'll separate sometime for that.
Regarding the weblate/pootle thing: I need to confirm with my associates if we still can provide the server. The ideal thing is to talk to osgeo to see if they have a spare webserver for that. There are many projects that could use the same resource instead of using transifex. I'll take that to the osgeo list. If they provide the server, we can customize the auth, so it will look at osgeo's LDAP and provide some maintenance.
Now, for what I can see, the resources are pointing to svn-trunk.
@Regina, I took a look at the generated docs, and it looks like they are built from another branch, not svn-trunk. I can tell that because pt-br has the highest number of strings translated and a number of them are not translated.
Perhaps you generated the docs from the master? How are PostGIS branches organized these days btw?
Thanks!
On Mon, Jan 30, 2017 at 2:31 PM, Sandro Santilli <strk at kbt.io <mailto:strk at kbt.io> > wrote:
On Mon, Jan 30, 2017 at 08:31:39AM -0200, George Silva wrote:
> Thanks Regina.
> @strk: for what I know the docs are only updated on transifex when the
> changes hit the svn-trunk branch, correct?
George: you know Transifex better than I do, so please find out and
let us know :) --- note I'm still happy to switch from transifex
to weblate if you're up for championing that
(https://weblate.org/en/hosting/)
> Is there anything we can help in these proceedings?
Maybe improve doc/po/README with the recommended workflow
for updates, in both branches and trunk ?
--strk;
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
George R. C. Silva
Sigma Geosistemas LTDA
http://www.sigmageosistemas.com.br/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170130/122851fa/attachment.html>
