[postgis-devel] Docs broken for other languages
George Silva georger.silva at gmail.com
Tue Jan 31 11:38:25 PST 2017
Good news. We are up and running the new docs.
I have to install gnome-doc-utils to use the po2xml util.
I guess that we do need some work on the readme with this. I'll try to add
this to the docs readme.
Are we accepting PRs on github?
George
On Tue, Jan 31, 2017 at 5:33 PM, George Silva <georger.silva at gmail.com>
wrote:
> I needed to run ./autogen first, then the ./configure file showed up.
> Now I have run configure.
> The pull-tx command is running again, just to be sure. (I used the same
> command that is described in the makefile, but..)
> After that let's see if I can run make html-localize :D
> Thanks
> On Tue, Jan 31, 2017 at 5:18 PM, Sandro Santilli <strk at kbt.io> wrote:
>> On Tue, Jan 31, 2017 at 04:02:19PM -0200, George Silva wrote:
>> > george at winterfell ~/projetos/postgis/doc $ make html-localized
>> > make: *** No rule to make target 'html-localized'.  Stop.
>> > george at winterfell ~/projetos/postgis/doc $ make pull-tx
>> > make: *** No rule to make target 'pull-tx'.  Stop.
>> Did you run ./configure from the top-level dir ?
>> You'd get that message in absence of a Makefile
>> (which is generated by ./configure from Makefile.in)
>> > I'm a little green with makefiles :D
>> First step is *having* a Makefile, see if you can get there :)
>> --strk;
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
> George R. C. Silva
> Sigma Geosistemas LTDA
> http://www.sigmageosistemas.com.br/
George R. C. Silva
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170131/5aa4dbf5/attachment.html>
