[postgis-devel] Docs broken for other languages
George Silva georger.silva at gmail.com
Tue Jan 31 11:55:45 PST 2017
Great, I've managed to generate the docs. Hooray for me.
There are way more problems then those that were on Regina's email.
Let me take a look on all of these errors so we can finally generate these.
Thanks for all the help folks.
On Tue, Jan 31, 2017 at 5:38 PM, George Silva <georger.silva at gmail.com>
wrote:
> Good news. We are up and running the new docs.
> I have to install gnome-doc-utils to use the po2xml util.
> I guess that we do need some work on the readme with this. I'll try to add
> this to the docs readme.
> Are we accepting PRs on github?
> George
> On Tue, Jan 31, 2017 at 5:33 PM, George Silva <georger.silva at gmail.com>
> wrote:
>> I needed to run ./autogen first, then the ./configure file showed up.
>> Now I have run configure.
>> The pull-tx command is running again, just to be sure. (I used the same
>> command that is described in the makefile, but..)
>> After that let's see if I can run make html-localize :D
>> Thanks
>> On Tue, Jan 31, 2017 at 5:18 PM, Sandro Santilli <strk at kbt.io> wrote:
>>> On Tue, Jan 31, 2017 at 04:02:19PM -0200, George Silva wrote:
>>> > george at winterfell ~/projetos/postgis/doc $ make html-localized
>>> > make: *** No rule to make target 'html-localized'.  Stop.
>>> > george at winterfell ~/projetos/postgis/doc $ make pull-tx
>>> > make: *** No rule to make target 'pull-tx'.  Stop.
>>> Did you run ./configure from the top-level dir ?
>>> You'd get that message in absence of a Makefile
>>> (which is generated by ./configure from Makefile.in)
>>> > I'm a little green with makefiles :D
>>> First step is *having* a Makefile, see if you can get there :)
>>> --strk;
>>> postgis-devel mailing list
>>> postgis-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
>> George R. C. Silva
>> Sigma Geosistemas LTDA
>> http://www.sigmageosistemas.com.br/
> George R. C. Silva
George R. C. Silva
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170131/d645c083/attachment.html>
