[postgis-devel] PostGIS 2.3.3 released
Regina Obe lr at pcorp.us
Mon Jul 3 06:29:55 PDT 2017
> Hi,
> On Sun, 2017-07-02 at 15:39 +0100, Devrim G nd z wrote:
>> This fails to build on RHEL 6 - i386 :
>> https://www.gunduz.org/temp/postgis233-rhel6-i386.txt
> Sorry, this fails only against PostgreSQL 9.6.3 on RHEL 6 - i386. It builds fine against 9.5.
> Regards,
> Devrim G nd z
> EnterpriseDB: https://www.enterprisedb.com PostgreSQL Danismani/Consultant, Red Hat Certified Engineer
> Twitter: @DevrimGunduz , @DevrimGunduzTR
Devrim,
Thanks, for reporting.  I tested against a 9.6 but I think it was like 9.6.1 32-bit (mingw64).  Though our debian build bot tests against 9.6 nightly branch.
I have to recheck.
I assume from last email you tried 2.3.2 and that worked?
I wasn't clear from your first if you tried that already.
If others can try too that would be great.
Thanks,
Regina
