[postgis-devel] PostGIS (actually liblwgeom) integration with oss-fuzz
Regina Obe lr at pcorp.us
Thu Jul 13 15:20:09 PDT 2017
Even,
Thanks for the input.  I managed to create a docker build I could bash into
using the oss-fuzz plain build and some logic I borrowed from strks
postgis-docker.
I was able to get as far as:
cd fuzzers
make dummyfuzzers
and it generates /tmp/wkb_import_fuzzer and /tmp/wkt_import_fuzzer
then ran /tmp/wkb_import_fuzzer test-case-file-from-bug-report-here
and that segfaulted as expected.  Then I made changes to
ptarray_is_closed_2d and ptarray_is_closed_3d  and tested with my new
version
and didn't get a segfault anymore, though I'm not confident with my solution
so I'll commit that into my own repo for strk and pramsey to inspect.
The regress still pass with the change I made so I guess that's promising
That said, when trying to build with
CFLAGS="-fsanitize=undefined,address",
My configure just gives error
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: in `/postgis-trunk':
configure: error: C compiler cannot create executables
See `config.log' for more details
So I'm missing something here, perhaps a typo.
Thanks,
Regina
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Thursday, July 13, 2017 5:19 AM
To: postgis-devel at lists.osgeo.org
Cc: Regina Obe <lr at pcorp.us>
Subject: Re: [postgis-devel] PostGIS (actually liblwgeom) integration with
oss-fuzz
On mercredi 12 juillet 2017 18:38:24 CEST Regina Obe wrote:
> Yah I think your email has to be a gmail. I can see them, but my account
is
> under gmail.
> And yes I think we can setup locally if we want. I think Even had
> experimented with that. We'd probably want to setup locally anyway so we
> can test out changes before we add to our fuzz list. I haven't done the
leg
> work to figure out how to set up locally though and not sure when I'll
have
> time to do that. Strk -- if you want to take a stab at it, I'd be so happy
There are 2 different things :
- reproduce locally a bug found by oss-fuzz. You can just build the dummy
fuzzer in PostGIS by doing
cd fuzzers
make dummyfuzzers
Then download the reproducer test cases from the oss-fuzz ticket and do
/tmp/wkb_import_fuzzer the_file (or /tmp/wkt_import_fuzzer the_file
depending on which fuzzer found the issue)
Possibly under Valgrind, or with a PostGIS build configured with
CFLAGS="-fsanitize=undefined,address", so as to catch the issues that don't
systemetically translate to crashes.
- fuzz the code yourself. Then you need to use the oss-fuzz Python scripts
that rely on Docker underneath. See instructions in fuzzers/README.TXT
Even
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
Behalf
> Of Sandro Santilli Sent: Wednesday, July 12, 2017 4:23 PM
> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org
<mailto:postgis-devel at lists.osgeo.org> >
> oss-fuzz
> RE: fuzzers and Google buying us all
> I received a few (~5) email notification about bugs found by the fuzzer.
But
> when I clicked on the links I got a permission denied. Supposedly, I'd
have
> to create an account on Google, and be given permission to read that
> report. Is this correct ?
> Can we get those fuzz tests be run by our own bots ?
> Like drone ? Drone is already docker based, if that was the problem...
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170713/dec6f2ed/attachment.html>
