[postgis-devel] ST_CurveToLine extended API proposal
Tom van Tilburg tom.van.tilburg at gmail.com
Mon Jun 19 02:39:17 PDT 2017
Superb! Really happy with this new behaviour :)
On Mon, Jun 19, 2017 at 11:05 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Tue, Jun 13, 2017 at 09:06:53AM -0700, Paul Ramsey wrote:
> > All equal lengths has nice properties in terms of both regular lengths
> and
> > regular angles between segments. If you can do it, I don't really see the
> > point in other "lesser" options. Also, am fine WRT to the API as long as
> we
> > preserve the backwards compatibility, as we do know that lots of people
> use
> > these functions, so behavior changes on the old API *will* cause
> complaints.
> All-equal-lengths is now implemented in the PR:
> https://gitlab.com/postgis/postgis/merge_requests/3
> As of commit b9599af94321d7c9585d59bd5f9202975d7768b5
> It'll be done when passing LW_LINEARIZE_FLAG_SYMMETRIC flag
> to this new liblwgeom function:
>    LWGEOM* lwcurve_linearize(const LWGEOM *geom, double tol,
>                              LW_LINEARIZE_TOLERANCE_TYPE type, int flags);
> Backward compatibility is retained (lwgeom_stroke calls
> lwcurve_linearize with flags and types retaining backward
> compatibility).
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170619/a77b6ee0/attachment.html>
