[postgis-devel] manual-dev generation
Regina Obe lr at pcorp.us
Mon Jun 19 12:39:47 PDT 2017
It updates after successful run of debbie's  trunk job.
Looks like debbie's trunk job failed on PostgreSQL 10 run in topology.
Guess they instituted a change for set-returning CASE WHEN after my
complaint, so time to refix the topology fix I put in for CASE WHEN.
Hopefully it's only a matter of fixing
https://trac.osgeo.org/postgis/ticket/3764
I'll try to get to that today.
https://debbie.postgis.net/job/PostGIS_Regress/5595/consoleFull
PostgreSQL 10beta1 on x86_64-pc-linux-gnu, compiled by gcc (Debian 5.2.1-22)
5.2.1 20151010, 64-bit
  Postgis 2.4.0dev - r15433 - 2017-06-19 18:39:00
  scripts 2.4.0dev r15433
  GEOS: 3.7.0dev-CAPI-1.11.0 8fe2ce62
  PROJ: Rel. 4.9.2, 08 September 2015
Running tests
 regress/legacy_validate .. ok
 regress/legacy_predicate .. ok
 regress/legacy_invalid .. ok
 regress/sqlmm .. ok
 regress/legacy_query .. ok
 regress/addnode .. ok
 regress/addedge .. ok
 regress/addface .. ok
 regress/addface2.5d .. ok
 regress/addtopogeometrycolumn .. ok
 regress/polygonize .. ok
 regress/st_addisoedge .. ok
 regress/st_addisonode .. ok
 regress/st_addedgemodface .. ok
 regress/st_addedgenewfaces .. ok
 regress/st_changeedgegeom .. ok
 regress/st_createtopogeo .. ok
 regress/st_getfacegeometry .. ok
 regress/st_getfaceedges .. ok
 regress/st_modedgeheal .. ok
 regress/st_modedgesplit .. ok
 regress/st_newedgeheal .. ok
 regress/st_newedgessplit .. ok
 regress/st_remedgenewface .. ok
 regress/st_remedgemodface .. ok
 regress/st_simplify .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_26_diff)
--- regress/st_simplify_expected	2017-02-07 07:21:40.613359496 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_26_out
2017-06-19 18:45:00.070826465 +0000
@@ -1,9 +1,8 @@
 t
 L1
-N2
-S1|f|t
-S2|f|t
+ERROR:  set-returning functions are not allowed in CASE at character 227
+N1
+S1|f|
+S2|f|
 L2
-HS1|f|t
-HS2|f|t
 f
 regress/topoelement .. ok
 regress/topoelementarray_agg .. ok
 regress/topogeo_addlinestring .. ok
 regress/topogeo_addpoint .. ok
 regress/topogeo_addpolygon .. ok
 regress/topogeom_edit .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_32_diff)
--- regress/topogeom_edit_expected	2017-02-07 07:21:40.665359497 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_32_out
2017-06-19 18:45:04.182826481 +0000
@@ -1,8 +1,5 @@
 create|t
 simple_line_layer|1
-1|start|1|10
-1|add|1|30
-1|rem|1|20
-1|dup|1|20
-1|mis|1|20
 Topology 'tt' dropped
 regress/topogeometry_type .. ok
 regress/topojson .. ok
 regress/topologysummary .. ok
 regress/topo2.5d .. ok
 regress/totopogeom .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_37_diff)
--- regress/totopogeom_expected	2017-02-07 07:21:40.633359496 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_37_out
2017-06-19 18:45:07.298826492 +0000
@@ -18,13 +18,13 @@
 ERROR:  Unsupported feature type TIN
 ERROR:  Unsupported feature type TRIANGLE
 ERROR:  Unsupported feature type CIRCULARSTRING
-POINT(0 0)|t
-LINESTRING(0 10,10 10)|t
-POLYGON((0 20,10 20,5 30,0 20),(2 22,8 22,5 28,2 22))|t
-MULTIPOINT(0 -10,5 -10)|t
-MULTILINESTRING((-1 10,-10 10),(-10 8,-2 9))|t
-MULTIPOLYGON(((100 20,110 20,105 30,100 20),(102 22,108 22,105 28,102
22)),((80 20,90 20,90 60,80 20)))|t
-GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90
-90),POLYGON((-100 -80,-90 -80,-95 -70,-100 -80),(-98 -78,-92 -78,-95
-72,-98 -78)),MULTIPOINT(-100 -110,-95 -110),LINESTRING
EMPTY,MULTILINESTRING((-101 -90,-110 -90),(-110 -92,-102
-91)),MULTIPOLYGON(((0 -80,10 -80,5 -70,0 -80),(2 -78,8 -78,5 -72,2
-78)),((-20 -80,-10 -80,-10 -40,-20
-80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-100 -80,-95 -70,-90 -80,-100
-80),(-98 -78,-92 -78,-95 -72,-98 -78)),((0 -80,5 -70,10 -80,0 -80),(2 -78,8
-78,5 -72,2 -78)),((-20 -80,-10 -40,-10 -80,-20 -80))),MULTILINESTRING((-110
-92,-102 -91),(-101 -90,-110 -90),(-100 -90,-90 -90)),MULTIPOINT(-100
-110,-100 -100,-95 -110))
 MULTIPOINT EMPTY
 MULTIPOINT EMPTY
 MULTILINESTRING EMPTY
@@ -32,21 +32,19 @@
 MULTIPOLYGON EMPTY
 MULTIPOLYGON EMPTY
 GEOMETRYCOLLECTION EMPTY
-tolerance_1|0.5
-tolerance_topo_1|0.5
-tolerance_0|0
-custom_search_path|0
-#1790.1|0|0
-#1790.2|0|0
-#1790.3|0|0
-#1968.1|0
-#1968.2|0
-tgup1.1|5|100|1
-tgup1.2|5|200|2
-tgup1.3|5|200|4
 #3359.setval|1|2|1
-#3359.line.1|1
-#3359.line.2|2
-#3359.area.1|1
-#3359.area.2|2
 regress/droptopology .. ok
 regress/droptopogeometrycolumn .. ok
 regress/copytopology .. ok
 regress/createtopogeom .. ok
 regress/createtopology .. ok
 regress/gml .. ok
 regress/getnodebypoint .. ok
 regress/getedgebypoint .. ok
 regress/getfacebypoint .. ok
 regress/getringedges .. ok
 regress/gettopogeomelements .. ok
 regress/layertrigger .. ok
 regress/validatetopology .. ok
 uninstall .
/var/lib/jenkins/workspace/postgis/branches/2.4/regress/00-regress-install/s
hare/contrib/postgis/uninstall_topology.sql
hare/contrib/postgis/uninstall_postgis.sql
. ok (4662)
Run tests: 51
Failed: 3
-----Original Message-----
Sent: Monday, June 19, 2017 3:23 PM
To: postgis-devel at lists.osgeo.org
Cc: Paragon Corporation <lr at pcorp.us>
Subject: manual-dev generation
I've committed changes to manual page about 5 hours ago but it is not
reflected here:
http://postgis.net/docs/manual-dev/ST_CurveToLine.html
How's that page supposed to be updated ?
--strk;
