[postgis-devel] [postgis-tickets] r15439 - Clean up of formatting of r15406.
Sandro Santilli strk at kbt.io
Wed Jun 21 03:15:17 PDT 2017
On Tue, Jun 20, 2017 at 04:29:37PM -0700, Regina Obe wrote:
> --- trunk/topology/sql/topogeometry/totopogeom.sql.in	2017-06-20 22:16:18 UTC (rev 15438)
> +++ trunk/topology/sql/topogeometry/totopogeom.sql.in	2017-06-20 23:29:37 UTC (rev 15439)
> @@ -236,16 +236,24 @@
>    -- definition by splitting
>    FOR rec IN SELECT id(tg), alayer as lyr,
>      geom, ST_Dimension(geom) as dims
> -    FROM (SELECT (ST_Dump(ageom)).geom) as f
> +    FROM (SELECT gd.geom FROM ST_Dump(ageom) AS gd ) as f
How about this simplification:
       FROM ST_Dump(ageom)
--strk;
