[postgis-devel] I'd like to remove this Toast discussion
Javier Santana jsantana at carto.com
Fri Jun 30 08:44:35 PDT 2017
When I implemented the st_getgeometrytype version [1] (that Paul finally
merged into postgis master) it was faster but Paul is right. My proposal
here would be to change the pglz_decompress [2] function, called
from PG_DETOAST_DATUM_SLICE (which is the macro we use to get a slice of
the data).
The algorithm seems easy enough to change and it might get into postgres 10.
In any case, there are two things we could do to improve this:
1) use the same pglz_compress postgres has but calling it from postgis
source and have a HEADER + COMPRESSED_GEOMETRY
2) if we do that, we could encode the geometry by component so it  compress
better
Cheers!
[1]
https://github.com/javisantana/postgis/commit/fbc45b0486be558f77b8c89de0f3f30274be2b90
[2]
https://github.com/postgres/postgres/blob/master/src/common/pg_lzcompress.c#L682
On Fri, Jun 30, 2017 at 5:18 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> On Thu, Jun 29, 2017 at 10:31 PM, Regina Obe <lr at pcorp.us> wrote:
>> https://postgis.net/docs/performance_tips.html#small_tables_large_objects
>> This is the last bit of business before I can release PostGIS 2.3.3.
>> I'd like to get rid of this whole discussion of TOAST as I don't think
>> it's
>> relevant anymore.
>> Am I correct in assuming that?
>> My assumption of why I think it's not relevant anymore is that we store
>> cached boxes for most geometries except for Points and 2 point lines.
>> So isn't it so that even if there is no index on a geometry, we do not
>> need
>> to fully detoast (or possibly not to detoast at all) the geometry to read
>> the bounding box.
>> That it is part of the head of the geometry?
> No, that is not so. If the object is large enough that it requires
> toasting, the whole thing is stuffed off to the side table and replaced
> with a reference in the main tuple. In order to get at that bbox on the
> header, we have to .... go to the toast tables and re-assemble the thing.
> "Worse", since we use compression on large objects, the object is
> compressed in the side tables and is pulled back in its entirety, then
> decompressed, then just the header is read.
> Changing that would involve storing objects uncompressed and implementing
> any compression we wanted internal to the postgis library. So we'd have
> some logic to compress anything larger than N vertices, but would always
> leave the header uncompressed so we could peak at it for free.
> That would *still* leave the toasting problem, which I'd have to
> re-confirm whether a pg_datum_slice cleanly pulls out just one piece of the
> toasted object or actually pulls the whole thing back first.
> P.
>> I did a quick test of my states table - 52 records (granted they aren't
>> huge, but toast size is about 14 MB)
>> When I do something like below without forcing enable_seqscan = false; it
>> doesn't use an index (well sometimes it does even without urging)
>> SELECT stusps
>> from tiger_data.state_all
>> WHERE the_geom &&
>> ST_Buffer('0101000020AD100000242F4BF9462754C0BD0F7DA33F524340'::geometry,
>> 5);
>> But whether it uses an index or not, the timing is still about the same -
>> under 10ms.
>> Though interestingly switching to
>> SELECT stusps
>> FROM tiger_data.state_all
>> WHERE ST_Intersects(the_geom,
>> 5));
>> Does always force an index scan.
>> Thanks,
>> Regina
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
-- CARTO CTO
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170630/99fedfc6/attachment.html>
