[postgis-devel] [postgis-users] raster2pgsql: out_db=false with -R flag (And Showing out_db rasters in QGIS)
kit kit at hypostasis.com
Tue May 2 13:36:39 PDT 2017
Is there a potential issue with how gdal expects to see the raster and
in particular the metadata it gets from raster_columns? I've some
trouble with GDAL and partitioning that I need to work through at some
point - but that for the moment I'm effectvely materializing a view ov
my underlying tables to subsequently generate the statistics and
constraints that GDAL want to see.
On 02/05/2017 21:24, Regina Obe wrote:
> Disregard what I said.  I see that the SQL statements I thought
> mistakenly were coming from DbManager are generated by GDAL (looking
> at the GDAL postgis raster code).
> So the change would need to be done in GDAL driver.   I think having a
> PostGIS function GDAL can count on calling that would always return
> the materialized raster tile would simplify things though.
> So I'm thinking strongly of implementing that in PostGIS 2.4. I think
> all other calls that GDAL is doing to for example get meta data and
> overviews would be the same for out-db as it is for in-db.
> Even,
> Any input you have on the matter would be very welcomed.  I guess this
> would need to wait for GDAL 2.2 or 2.3 and verify said helper function
> exists (or version of PostGIS) before it can be used.
> Thanks,
> Regina
> *From:*Regina Obe [mailto:lr at pcorp.us]
> *Sent:* Tuesday, May 02, 2017 4:04 PM
> *To:* 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
> *Cc:* 'PostGIS Development Discussion' <postgis-devel at lists.osgeo.org>
> *Subject:* RE: [postgis-users] raster2pgsql: out_db=false with -R flag
> Just to add the bug regarding raster2pgsql will be fixed in upcoming 2.3.3
> And the work-around is to use –Y with –s  as detailed in the ticket.
> https://trac.osgeo.org/postgis/ticket/3738
> Regarding the QGIS issue with GDAL not supporting out-db.   I've been
> thinking that the easier fix might be to make the change in QGIS
> DbManager instead of PostGIS.
> The ultimate problem is that PostGIS is feeding an out-db raster
> instead of the raster bytes.  QGIS just makes queries to the PostGIS
> database and uses GDAL to consume the raw bytes.
> If QGIS dbmanager were to instead of doing SELECT rast … did something
> like  SELECT ST_Materialize(rast) AS rast …. FROM somerast table …
> Where yet to be implemented PostGIS function ST_Materialize or
> whatever we decide to call it does nothing with in-db, but returns the
> raster bytes of out-db, then QGIS DbManager can treat out-db like any
> in-db raster.
> I'm thinking this would be a faster fix than mucking with PostGIS GDAL
> driver and in the end might help simplify the PostGIS GDAL driver
> handling of out-db since it can use the same function.
> strk,
> I think you are familiar with the internal workings of  QGIS Db
> Manager.  You think this proposed option is feasible and less taxing
> or we'd still need to do something on the GDAL end to make this work?
> Thanks,
> Regina
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Tumasgiu Rossini
> *Sent:* Tuesday, May 02, 2017 8:26 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>>
> *Subject:* Re: [postgis-users] raster2pgsql: out_db=false with -R flag
> I think that raster2pgsql is indeed a mature tool, but it is the
> out-db feature of postgis
> which is maybe not widely used, and so the bugs takes more time to
> appear because
> of the fewer users.
> 2017-05-02 12:18 GMT+02:00 <Michael.Haertel at t-systems.com
> <mailto:Michael.Haertel at t-systems.com>>:
>     Hello Tumasgiu Rossini,
>     thank you very much for your fast and comprehensive response. I
>     was not aware of that bug yet but found so many references to
>     raster2pgsql that I just assumed that it was a mature tool already.
>     (And noted that I gave wrong parameter in the subject line of my
>     mail, should have been R and not F).
>     Good luck with your programming efforts. I guess it’s somewhat
>     complex since you have to deal with the real pixel data.
>     Regards,
>     Michael
>     *Von:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org
>     <mailto:postgis-users-bounces at lists.osgeo.org>] *Im Auftrag von
>     *Tumasgiu Rossini
>     *Gesendet:* Dienstag, 2. Mai 2017 12:08
>     *An:* PostGIS Users Discussion
>     *Betreff:* Re: [postgis-users] raster2pgsql: out_db=false with -F
>     Hi,
>     To answer your first question :
>     the combination of the -s and -R options actually transforms
>     out-db raster into in-db,
>     it is a recent known bug, see
>     https://lists.osgeo.org/pipermail/postgis-users/2017-April/042003.html
>     for more information.
>     For the latter question,
>     Qgis uses gdal to fetch raster data from postgis and the out-db
>     support is not implemented.
>     You can though maybe use workarounds, more info here :
>     https://lists.osgeo.org/pipermail/postgis-users/2017-April/042077.html
>     https://lists.osgeo.org/pipermail/postgis-users/2017-April/042053.html
>     Using out-db rasters and Qgis at my company, I am facing myself
>     this problem and
>     I am trying to implement out-db support in gdal, though I am no
>     gdal developer
>     and it is not a high priority feature.
>     2017-05-02 11:37 GMT+02:00 <Michael.Haertel at t-systems.com
>     Dear users,
>     I hope that somebody can tell me if I found a bug or simply don’t
>     use the command correctly.
>     Given:
>     ·A directory with four GeoTIFF files
>     ·PostgreSQL 9.6.1, compiled by Visual C++ build 1800, 64-bit
>     ·POSTGIS="2.3.1 r15264" GEOS="3.6.0-CAPI-1.10.0 r4265"
>     SFCGAL="1.3.0" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.1.1,
>     released 2016/07/07" LIBXML="2.7.8" LIBJSON="0.12" RASTER
>     ·OS is Windows 7
>     I try to import the Tiff files as OUT_DB raster files using this
>     command:
>     1.raster2pgsql.exe -s 25832 -I -R -n myFilename -C -M -F
>     C:\_GEODATA_\*.tif raster2x2 > t:\DTK10.sql
>     Output:
>     a.Processing 1/4: C:\_GEODATA_\24_dtk10_32356_5608_2_nw_col.tif
>     b.Processing 2/4: C:\_GEODATA_\25_dtk10_32356_5610_2_nw_col.tif
>     c.Processing 3/4: C:\_GEODATA_\34_dtk10_32358_5608_2_nw_col.tif
>     d.Processing 4/4: C:\_GEODATA_\35_dtk10_32358_5610_2_nw_col.tif
>     2.psql.exe --host=localhost --port=5432 --username=xxx
>     --dbname=xxx -f t:\DTK10.sql
>     Output:
>     a.BEGIN
>     b.CREATE TABLE
>     c.INSERT 0 1
>     d.INSERT 0 1
>     e.INSERT 0 1
>     f.INSERT 0 1
>     g.CREATE INDEX
>     h.ANALYZE
>     i.psql:t:/DTK10.sql:9: HINWEIS:  Adding SRID constraint
>     j.psql:t:/DTK10.sql:9: HINWEIS:  Adding scale-X constraint
>     k.psql:t:/DTK10.sql:9: HINWEIS:  Adding scale-Y constraint
>     l.psql:t:/DTK10.sql:9: HINWEIS:  Adding blocksize-X constraint
>     m.psql:t:/DTK10.sql:9: HINWEIS:  Adding blocksize-Y constraint
>     n.psql:t:/DTK10.sql:9: HINWEIS:  Adding alignment constraint
>     o.psql:t:/DTK10.sql:9: HINWEIS:  Adding number of bands constraint
>     p.psql:t:/DTK10.sql:9: HINWEIS:  Adding pixel type constraint
>     q.psql:t:/DTK10.sql:9: HINWEIS:  Adding nodata value constraint
>     r.psql:t:/DTK10.sql:9: HINWEIS:  Adding out-of-database constraint
>     s.psql:t:/DTK10.sql:9: HINWEIS:  Adding maximum extent constraint
>     t.addrasterconstraints
>     u.----------------------
>     v.t
>     Problem is that the view “raster_columns” always shows FALSE for
>     out_db, even though I used the F flag:
>     "r_table_catalog"
>     "r_table_schema"
>     "r_table_name"
>     "r_raster_column"
>     "srid"
>     "scale_x"
>     "scale_y"
>     "blocksize_x"
>     "blocksize_y"
>     "same_alignment"
>     "regular_blocking"
>     "num_bands"
>     "pixel_types"
>     "nodata_values"
>     "out_db"
>     "extent"
>     "spatial_index"
>     "gismobile"
>     "public"
>     "raster2x2 "
>     "rast"
>     25832
>     0.5
>     -0.5
>     4000
>     4000
>     true
>     false
>     1
>     {8BUI}
>     {NULL}
>     {f}
>     0103000020E864000001000000050000000000000080BA154100000000906455410000000080BA154100000000786855410000000000F9154100000000786855410000000000F9154100000000906455410000000080BA15410000000090645541
>     true
>     "rid"
>     "rast"
>     "filename"
>     1
>     0100000100000000000000E03F000000000000E0BF0000000080BA1541000000008466554100000000000000000000000000000000E8640000A00FA00F840000433A5C5F47454F444154415F5C32345F64746B31305F33323335365F353630385F325F6E775F636F6C2E74696600
>     "24_dtk10_32356_5608_2_nw_col.tif"
>     2
>     0100000100000000000000E03F000000000000E0BF0000000080BA1541000000007868554100000000000000000000000000000000E8640000A00FA00F840000433A5C5F47454F444154415F5C32355F64746B31305F33323335365F353631305F325F6E775F636F6C2E74696600
>     "25_dtk10_32356_5610_2_nw_col.tif"
>     3
>     0100000100000000000000E03F000000000000E0BF00000000C0D91541000000008466554100000000000000000000000000000000E8640000A00FA00F840000433A5C5F47454F444154415F5C33345F64746B31305F33323335385F353630385F325F6E775F636F6C2E74696600
>     "34_dtk10_32358_5608_2_nw_col.tif"
>     4
>     0100000100000000000000E03F000000000000E0BF00000000C0D91541000000007868554100000000000000000000000000000000E8640000A00FA00F840000433A5C5F47454F444154415F5C33355F64746B31305F33323335385F353631305F325F6E775F636F6C2E74696600
>     "35_dtk10_32358_5610_2_nw_col.tif"
>     What I found out: As soon as I omit the s flag (to provide a SRS)
>     the column shows TRUE.
>     I guess that this is not the intended behaviour is it?
>     My QGIS 2.18 only shows black boxes for out_db rasters, the
>     rasters themselves (pixel values) only appear for “in-DB” rasters.
>     Did anybody succeed in showing out_db rasters in QGIS?
>     Interestiung is also that gdalinfo is not showing any extents
>     although it shows correct SRS and the “extent” column is populated
>     (see above):
>     C:\_PortableApps_\pgsql\bin>"c:\QGIS\bin\gdalinfo.exe"
>     PG:"dbname='xxx' host='localhost' port='5432' user='mhaerte2'
>     password='xxx' table='raster2x2'"
>     Driver: PostGISRaster/PostGIS Raster driver
>     Files: none associated
>     Size is 0, 0
>     Coordinate System is:
>     PROJCS["ETRS89 / UTM zone 32N",
>         GEOGCS["ETRS89",
>     DATUM["European_Terrestrial_Reference_System_1989",
>     SPHEROID["GRS 1980",6378137,298.257222101,
>     AUTHORITY["EPSG","7019"]],
>     TOWGS84[0,0,0,0,0,0,0],
>     AUTHORITY["EPSG","6258"]],
>     PRIMEM["Greenwich",0,
>     AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>     AUTHORITY["EPSG","9122"]],
>     AUTHORITY["EPSG","4258"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",9],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>         UNIT["metre",1,
>     AUTHORITY["EPSG","9001"]],
>     AXIS["Easting",EAST],
>     AXIS["Northing",NORTH],
>     AUTHORITY["EPSG","25832"]]
>     Subdatasets:
>              --- snip! --
>     Corner Coordinates:
>     Upper Left  (    0.0, 0.0)
>     Lower Left  (    0.0, 0.0)
>     Upper Right (    0.0, 0.0)
>     Lower Right (    0.0, 0.0)
>     Center      (    0.0, 0.0)
>     Does anyone have a clue?
>     Thank you for your comments,
>     Michael
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/postgis-users
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170502/87146f15/attachment.html>
