[postgis-devel] [postgis-users] raster2pgsql: out_db=false with -R flag (And Showing out_db rasters in QGIS)
Regina Obe lr at pcorp.us
Tue May 2 14:26:25 PDT 2017
Kit,
What sort of problems are you encountering?
If you have constraints on your current tables and are using for example a parent table, then the raster_columns would only consider the constraints applied to the parent table, not the child tables.  This may or may not be okay depending on what you are doing.  It also does require you make sure you have spatial indexes on the parent table even if your parent table is always empty.
Also I don't think GDAL uses raster_columnn view as much as it could.
Case in point: this part that tries to find a spatial index:
https://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/postgisraster/postgisrasterdataset.cpp#L316
I think part of the reason for that – like verifying existence of indexes appeared in GDAL first before appearing in raster_columns or simultaneously appeared, so GDAL reimplements some of the query logic used by raster_columns.
There was also a period of flux between 2.0 and 2.1 where some raster_columns were renamed, removed, added so that GDAL couldn't consistently rely on them without checking PostGIS version.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of kit
Sent: Tuesday, May 02, 2017 4:37 PM
To: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-devel] [postgis-users] raster2pgsql: out_db=false with -R flag (And Showing out_db rasters in QGIS)
Is there a potential issue with how gdal expects to see the raster and in particular the metadata it gets from raster_columns? I've some trouble with GDAL and partitioning that I need to work through at some point - but that for the moment I'm effectvely materializing a view ov my underlying tables to subsequently generate the statistics and constraints that GDAL want to see.
On 02/05/2017 21:24, Regina Obe wrote:
Disregard what I said.  I see that the SQL statements I thought mistakenly were coming from DbManager are generated by GDAL (looking at the GDAL postgis raster code).
So the change would need to be done in GDAL driver.   I think having a PostGIS function GDAL can count on calling that would always return the materialized raster tile would simplify things though.
So I'm thinking strongly of implementing that in PostGIS 2.4.  I think all other calls that GDAL is doing to for example get meta data and overviews would be the same for out-db as it is for in-db.
Even,
Any input you have on the matter would be very welcomed.  I guess this would need to wait for GDAL 2.2 or 2.3 and verify said helper function exists (or version of PostGIS) before it can be used.
Thanks,
Regina
Sent: Tuesday, May 02, 2017 4:04 PM
To: 'PostGIS Users Discussion'  <mailto:postgis-users at lists.osgeo.org> <postgis-users at lists.osgeo.org>
Cc: 'PostGIS Development Discussion'  <mailto:postgis-devel at lists.osgeo.org> <postgis-devel at lists.osgeo.org>
Subject: RE: [postgis-users] raster2pgsql: out_db=false with -R flag (And Showing out_db rasters in QGIS)
Just to add the bug regarding raster2pgsql will be fixed in upcoming 2.3.3
And the work-around is to use –Y with –s  as detailed in the ticket.
https://trac.osgeo.org/postgis/ticket/3738
Regarding the QGIS issue with GDAL not supporting out-db.   I've been thinking that the easier fix might be to make the change in QGIS DbManager instead of PostGIS.
The ultimate problem is that PostGIS is feeding an out-db raster instead of the raster bytes.  QGIS just makes queries to the PostGIS database and uses GDAL to consume the raw bytes.
If QGIS dbmanager were to instead of doing SELECT rast … did something like  SELECT ST_Materialize(rast) AS rast …. FROM somerast table …
Where yet to be implemented PostGIS function ST_Materialize or whatever we decide to call it does nothing with in-db, but returns the raster bytes of out-db, then QGIS DbManager can treat out-db like any in-db raster.
I'm thinking this would be a faster fix than mucking with PostGIS GDAL driver and in the end might help simplify the PostGIS GDAL driver handling of out-db since it can use the same function.
strk,
I think you are familiar with the internal workings of  QGIS Db Manager.  You think this proposed option is feasible and less taxing or we'd still need to do something on the GDAL end to make this work?
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Tumasgiu Rossini
Sent: Tuesday, May 02, 2017 8:26 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Subject: Re: [postgis-users] raster2pgsql: out_db=false with -R flag (And Showing out_db rasters in QGIS)
I think that raster2pgsql is indeed a mature tool, but it is the out-db feature of postgis
which is maybe not widely used, and so the bugs takes more time to appear because
of the fewer users.
2017-05-02 12:18 GMT+02:00 <Michael.Haertel at t-systems.com <mailto:Michael.Haertel at t-systems.com> >:
Hello Tumasgiu Rossini,
thank you very much for your fast and comprehensive response. I was not aware of that bug yet but found so many references to raster2pgsql that I just assumed that it was a mature tool already.
(And noted that I gave wrong parameter in the subject line of my mail, should have been R and not F).
Good luck with your programming efforts. I guess it’s somewhat complex since you have to deal with the real pixel data.
Regards,
Michael
Von: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] Im Auftrag von Tumasgiu Rossini
Gesendet: Dienstag, 2. Mai 2017 12:08
An: PostGIS Users Discussion
Betreff: Re: [postgis-users] raster2pgsql: out_db=false with -F flag (And Showing out_db rasters in QGIS)
To answer your first question :
the combination of the -s and -R options actually transforms out-db raster into in-db,
it is a recent known bug, see https://lists.osgeo.org/pipermail/postgis-users/2017-April/042003.html
for more information.
For the latter question,
Qgis uses gdal to fetch raster data from postgis and the out-db support is not implemented.
You can though maybe use workarounds, more info here :
https://lists.osgeo.org/pipermail/postgis-users/2017-April/042077.html
https://lists.osgeo.org/pipermail/postgis-users/2017-April/042053.html
Using out-db rasters and Qgis at my company, I am facing myself this problem and
I am trying to implement out-db support in gdal, though I am no gdal developer
and it is not a high priority feature.
2017-05-02 11:37 GMT+02:00 <Michael.Haertel at t-systems.com <mailto:Michael.Haertel at t-systems.com> >:
Dear users,
I hope that somebody can tell me if I found a bug or simply don’t use the command correctly.
Given:
*         A directory with four GeoTIFF files
*         PostgreSQL 9.6.1, compiled by Visual C++ build 1800, 64-bit
*         POSTGIS="2.3.1 r15264" GEOS="3.6.0-CAPI-1.10.0 r4265" SFCGAL="1.3.0" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.1.1, released 2016/07/07" LIBXML="2.7.8" LIBJSON="0.12" RASTER
*         OS is Windows 7
I try to import the Tiff files as OUT_DB raster files using this command:
1.  raster2pgsql.exe -s 25832 -I -R -n myFilename -C -M -F C:\_GEODATA_\*.tif raster2x2 > t:\DTK10.sql
Output:
a.       Processing 1/4: C:\_GEODATA_\24_dtk10_32356_5608_2_nw_col.tif
b.      Processing 2/4: C:\_GEODATA_\25_dtk10_32356_5610_2_nw_col.tif
c.       Processing 3/4: C:\_GEODATA_\34_dtk10_32358_5608_2_nw_col.tif
d.      Processing 4/4: C:\_GEODATA_\35_dtk10_32358_5610_2_nw_col.tif
2.  psql.exe --host=localhost --port=5432 --username=xxx --dbname=xxx -f t:\DTK10.sql
Output:
a.       BEGIN
b.      CREATE TABLE
c.       INSERT 0 1
d.      INSERT 0 1
e.      INSERT 0 1
f.        INSERT 0 1
g.       CREATE INDEX
h.      ANALYZE
i.         psql:t:/DTK10.sql:9: HINWEIS:  Adding SRID constraint
j.        psql:t:/DTK10.sql:9: HINWEIS:  Adding scale-X constraint
k.       psql:t:/DTK10.sql:9: HINWEIS:  Adding scale-Y constraint
l.         psql:t:/DTK10.sql:9: HINWEIS:  Adding blocksize-X constraint
m.    psql:t:/DTK10.sql:9: HINWEIS:  Adding blocksize-Y constraint
n.      psql:t:/DTK10.sql:9: HINWEIS:  Adding alignment constraint
o.      psql:t:/DTK10.sql:9: HINWEIS:  Adding number of bands constraint
p.      psql:t:/DTK10.sql:9: HINWEIS:  Adding pixel type constraint
q.      psql:t:/DTK10.sql:9: HINWEIS:  Adding nodata value constraint
r.        psql:t:/DTK10.sql:9: HINWEIS:  Adding out-of-database constraint
s.       psql:t:/DTK10.sql:9: HINWEIS:  Adding maximum extent constraint
t.        addrasterconstraints
u.      ----------------------
v.       t
Problem is that the view “raster_columns” always shows FALSE for out_db, even though I used the F flag:
"r_table_catalog"
"r_table_schema"
"r_table_name"
"r_raster_column"
"srid"
"scale_x"
"scale_y"
"blocksize_x"
"blocksize_y"
"same_alignment"
"regular_blocking"
"num_bands"
"pixel_types"
"nodata_values"
"out_db"
"extent"
"spatial_index"
"gismobile"
"public"
"raster2x2 "
"rast"
25832
0.5
-0.5
4000
4000
true
false
1
{8BUI}
{NULL}
{f}
0103000020E864000001000000050000000000000080BA154100000000906455410000000080BA154100000000786855410000000000F9154100000000786855410000000000F9154100000000906455410000000080BA15410000000090645541
true
"rid"
"rast"
"filename"
1
0100000100000000000000E03F000000000000E0BF0000000080BA1541000000008466554100000000000000000000000000000000E8640000A00FA00F840000433A5C5F47454F444154415F5C32345F64746B31305F33323335365F353630385F325F6E775F636F6C2E74696600
"24_dtk10_32356_5608_2_nw_col.tif"
2
0100000100000000000000E03F000000000000E0BF0000000080BA1541000000007868554100000000000000000000000000000000E8640000A00FA00F840000433A5C5F47454F444154415F5C32355F64746B31305F33323335365F353631305F325F6E775F636F6C2E74696600
"25_dtk10_32356_5610_2_nw_col.tif"
3
0100000100000000000000E03F000000000000E0BF00000000C0D91541000000008466554100000000000000000000000000000000E8640000A00FA00F840000433A5C5F47454F444154415F5C33345F64746B31305F33323335385F353630385F325F6E775F636F6C2E74696600
"34_dtk10_32358_5608_2_nw_col.tif"
4
0100000100000000000000E03F000000000000E0BF00000000C0D91541000000007868554100000000000000000000000000000000E8640000A00FA00F840000433A5C5F47454F444154415F5C33355F64746B31305F33323335385F353631305F325F6E775F636F6C2E74696600
"35_dtk10_32358_5610_2_nw_col.tif"
What I found out: As soon as I omit the s flag (to provide a SRS) the column shows TRUE.
I guess that this is not the intended behaviour is it?
My QGIS 2.18 only shows black boxes for out_db rasters, the rasters themselves (pixel values) only appear for “in-DB” rasters. Did anybody succeed in showing out_db rasters in QGIS?
Interestiung is also that gdalinfo is not showing any extents although it shows correct SRS and the “extent” column is populated (see above):
C:\_PortableApps_\pgsql\bin>"c:\QGIS\bin\gdalinfo.exe" PG:"dbname='xxx' host='localhost' port='5432' user='mhaerte2' password='xxx' table='raster2x2'"
Driver: PostGISRaster/PostGIS Raster driver
Files: none associated
Size is 0, 0
Coordinate System is:
PROJCS["ETRS89 / UTM zone 32N",
    GEOGCS["ETRS89",
        DATUM["European_Terrestrial_Reference_System_1989",
            SPHEROID["GRS 1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            TOWGS84[0,0,0,0,0,0,0],
            AUTHORITY["EPSG","6258"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4258"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",9],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","25832"]]
Subdatasets:
         --- snip! --
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,    0.0)
Upper Right (    0.0,    0.0)
Lower Right (    0.0,    0.0)
Center      (    0.0,    0.0)
Does anyone have a clue?
Thank you for your comments,
Michael
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170502/1fd736dc/attachment.html>
