[postgis-devel] topology pgsql 10 regression failures
Regina Obe lr at pcorp.us
Fri May 26 10:35:38 PDT 2017
I beat you to it :)
https://trac.osgeo.org/postgis/ticket/3764
I'll try to fix when I get the chance.
BTW: For this error, are you seeing this one?
https://trac.osgeo.org/postgis/ticket/3759
/tmp/2.4.0dev_pg10_geos3.7.0dev_gdal2.1.3w64/test_89_diff)
--- tickets_expected   2016-09-26 01:59:38 -0400
+++ /projects/postgis/tmp/2.4.0dev_pg10_geos3.7.0dev_gdal2.1.3w64/test_89_out        2017-05-25 15:15:09 -0400
@@ -285,7 +285,7 @@
#3375|GEOMETRYCOLLECTION(POINT(0 -7))
#3399|1|1
#3399|10|10
-#3399|100|100
+#3399|100|99
#3399|1000|1000
ERROR:  invalid KML representation
#3437a|5
Do we go with float or float4.  If float4, I think you need to change the regression and also the pre-10 code.
the geometry regression in tickets caused by this change
 nd_stats = palloc(sizeof(float) * sslot.nnumbers);
 memcpy(nd_stats, sslot.numbers, sizeof(float) * sslot.nnumbers);
To:
 nd_stats = palloc(sizeof(float4) * sslot.nnumbers);
 memcpy(nd_stats, sslot.numbers, sizeof(float4) * sslot.nnumbers);
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Friday, May 26, 2017 11:13 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: [postgis-devel] topology pgsql 10 regression failures
Several failures for me (Darwin Kernel Version 15.6.0) right now in topology, for example,
regress/st_simplify .. failed (diff expected obtained: /tmp/pgis_reg/test_26_diff)
This "invalid geometry type" shows up in a few of the other failures further down. Anyone seeing similar things w/ pgsql 10?
--- regress/st_simplify_expected    2014-12-01 12:28:41.000000000 -0800
+++ /tmp/pgis_reg/test_26_out   2017-05-26 08:02:22.000000000 -0700
@@ -1,9 +1,8 @@
 t
 L1
-N2
-S1|f|t
-S2|f|t
+ERROR:  Invalid geometry type (POLYGON) passed to TopoGeo_AddLinestring, expected LINESTRING
+N1
+S1|f|
+S2|f|
 L2
-HS1|f|t
-HS2|f|t
 f
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170526/2445b9aa/attachment.html>
