[postgis-devel] Testing pgRouting
Paragon Corporation lr at pcorp.us
Fri Nov 3 13:54:00 PDT 2017
In Taiwan.  I'll take a look when I get back next week.
Thanks,
Regina
On Fri, Nov 3, 2017 at 12:11 PM, Vicky Vergara <vicky at georepublic.de> wrote:
> ​Hi all,
> I used to be able to  test pgRouting ​using changing the postgis version
> to the latest version you rleased on AppVeyor testing CI.
> But I am stuck now on version 2.3.3
> Versions greater than that one give me this kind of error: (the 2.4 is
> because I tried to use postgis 2.4.1)
> ERROR: could not load library "C:/Program Files/PostgreSQL/9.4/lib/rtpostgis-2.4.dll":
> %1 is not a valid Win32 application.
> Like in the execution test on [1] line 1603
> The files involved for the AppVeyor tests are [2] & [3]
> Maybe you can give me a hand.
> Thanks
> Vicky
> [1] https://ci.appveyor.com/project/cvvergara/pgrouting/build/2.5.1890
> [2] https://github.com/pgRouting/pgrouting/blob/master/appveyor.yml
> [3] https://github.com/pgRouting/pgrouting/blob/master/ci/
> appveyor/install.bat
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20171103/69d3ffb1/attachment.html>
