[postgis-devel] Testing pgRouting
Vicky Vergara vicky at georepublic.de
Fri Nov 3 15:00:22 PDT 2017
ok, tomorrow, night.
On Fri, Nov 3, 2017 at 2:54 PM, Paragon Corporation <lr at pcorp.us> wrote:
> In Taiwan.  I'll take a look when I get back next week.
> Thanks,
> Regina
> On Fri, Nov 3, 2017 at 12:11 PM, Vicky Vergara <vicky at georepublic.de>
> wrote:
>> ​Hi all,
>> I used to be able to  test pgRouting ​using changing the postgis version
>> to the latest version you rleased on AppVeyor testing CI.
>> But I am stuck now on version 2.3.3
>> Versions greater than that one give me this kind of error: (the 2.4 is
>> because I tried to use postgis 2.4.1)
>> ERROR: could not load library "C:/Program Files/PostgreSQL/9.4/lib/rtpostgis-2.4.dll":
>> %1 is not a valid Win32 application.
>> Like in the execution test on [1] line 1603
>> The files involved for the AppVeyor tests are [2] & [3]
>> Maybe you can give me a hand.
>> Thanks
>> Vicky
>> [1] https://ci.appveyor.com/project/cvvergara/pgrouting/build/2.5.1890
>> [2] https://github.com/pgRouting/pgrouting/blob/master/appveyor.yml
>> [3] https://github.com/pgRouting/pgrouting/blob/master/ci/appvey
>> or/install.bat
>> Georepublic UG (haftungsbeschränkt)
>> Salzmannstraße 44,
>> 81739 München, Germany
>> Vicky Vergara
>> Operations Research
>> eMail: vicky at georepublic.de
>> Web: https://georepublic.info
>> Tel: +49 (089) 4161 7698-1
>> Fax: +49 (089) 4161 7698-9
>> Commercial register: Amtsgericht München, HRB 181428
>> CEO: Daniel Kastl
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20171103/c44483f7/attachment.html>
