[postgis-devel] Compiling PostGIS under FreeBSD 11
Regina Obe lr at pcorp.us
Sun Nov 26 10:19:19 PST 2017
I have a new FreeBSD 11 VM I'm planning to use for PostGIS regression
testing.  Dubbed Bessie ticketed here -
https://trac.osgeo.org/postgis/ticket/3936
I'm having some problems getting PostGIS to compile, any thoughts for fixing
would be helpful.
All the dependencies I have installed thus far using
Pkg install gdal geos proj  iconv  etc.
So I got this far using:
sh autogen.sh
./configure --with-projdir=/usr/local
PostGIS is now configured for amd64-unknown-freebsd11.1
 -------------- Compiler Info -------------
  C compiler:           cc -g -O2
  SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
 -------------- Dependencies --------------
  GEOS config:          /usr/local/bin/geos-config
  GEOS version:         3.6.2
  GDAL config:          /usr/local/bin/gdal-config
  GDAL version:         2.2.2
  PostgreSQL config:    /usr/local/bin/pg_config
  PostgreSQL version:   PostgreSQL 10.1
  PROJ4 version:        49
  Libxml2 config:       /usr/local/bin/xml2-config
  Libxml2 version:      2.9.4
  JSON-C support:       no
  protobuf-c support:   no
  PCRE support:         no
  Perl:                 /usr/local/bin/perl
 --------------- Extensions ---------------
  PostGIS Raster:       enabled
  PostGIS Topology:     enabled
  SFCGAL support:       disabled
  Address Standardizer support:       disabled
 -------- Documentation Generation --------
  xsltproc:             /usr/local/bin/xsltproc
  xsl style sheets:
  dblatex:
  convert:              /usr/local/bin/convert
  mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
It fails when it gets to compiling the loaders:
libtool: link: cc -I ../liblwgeom -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -I/usr/local/include shpopen.o dbfopen.o getopt.o
shpcommon.o safileio.o shp2pgsql-core.o shp2pgsql-cli.o -o .libs/shp2pgsql
-fstack-protector -Wl,--as-needed -Wl,-R/usr/local/lib
../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib -lgeos_c -lproj -lm
-lpthread -Wl,-rpath -Wl,/usr/local/lib
shp2pgsql-core.o: In function `utf8':
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:69:
undefined reference to `libiconv_open'
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:83:
undefined reference to `libiconv'
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:110:
undefined reference to `libiconv_close'
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:88:
undefined reference to `libiconvctl'
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:89:
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:92:
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:93:
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:101:
/usr/home/jenkins/workspace/Test_Slave/trunk/loader/shp2pgsql-core.c:97:
cc: error: linker command failed with exit code 1 (use -v to see invocation)
gmake[2]: *** [Makefile:103: shp2pgsql] Error 1
gmake[2]: Leaving directory
'/usr/home/jenkins/workspace/Test_Slave/trunk/loader'
gmake[1]: *** [GNUmakefile:16: all] Error 1
gmake[1]: Leaving directory '/usr/home/jenkins/workspace/Test_Slave/trunk'
*** Error code 2
I'm puzzled why iconv isn't in the lib includes.   I'm also puzzled why I
had to explicitly include reference to proj in my configure to have it
picked up.
Thanks,
Regina
